Results 21 to 29 of 29
November 25th, 2002 11:33 AM #24
Actually I was doing things the wrong way. Mula nang madetail ride ko, I was just applying the cleaner wax as a wax lang. Apply let haze then buff. Yung nasa pic, I rubbed the Cleaner Wax the way it should be used. Tapos buff and top off with the DC3. Aba iba ang results. Mas OK nga kinalabasan. PUmuti lalo ang paint. Hirap lang sa white, while rubbing the CW, you tend to get "silaw" after a while. Had to wear shades after 20 mins.
- 109
November 25th, 2002 01:53 PM #26ah okay!!! follow up question...
when is the right time to use a cleaner wax lang to remove contaminants and then wax compared to when do you need to use a polish, then wax?...
November 25th, 2002 02:20 PM #27
Kung OK na ang paint mo, use the cleaner wax then wax to maintain it lang. Kung napabayaan ng medyo matagal you have to do it the other way na.
- 109
November 25th, 2002 04:05 PM #28Black Magic,
Ah okay... So is it safe to use the cleaner wax as often as you like? Medyo talagang lito lang ako in the use of Cleaner wax and the Meg DC2 and DC3. Thanks for bearing with me...
By the way, we followed your tip last weekend, laki ng natipid namin sa waxing time... thanks a lot... we learned another thing nga pala... mas madali mag pa shine from haze (when the wax is dry) by applying a very very light mist spray of distilled water sa surface then wipe with the towel. ang bilis na kumintab... I guess, it helps sa pagpantay ng wax...
November 25th, 2002 04:17 PM #29
Glad to be of help. Well ako I use it almost every Sunday to maintain my car. No choice ako kasi white oto ko eh.
Xiaomi E-Car
