Quote Originally Posted by EGcoolmhan View Post
sir niky thanks for reply, sir gusto ko kasi kahit papaano eh may porma ang kotse ko kaya gusto ko i-drop kahit 1.5 lang.anu po bilhin ko na shocks(gas ba o fluid)pag nagpalowered ako?
1. ok pa naman paint niya may lumulubo sa bubong
2. kailangan ko na po palitan mga ito(thanks for suggestion)
3. shocks at spring?
4. mags at tires pag may sobra pa..
thanks guys!
Ok. Just as long as you know what's in good condition and what's not. You can skip the brakes if they're okay.
I'd get that roof repaired... it's common... di naman life-threatening, but the rust can spread.
Shocks and springs, sorry, I don't know what's good for your car, you'll have to ask around at Honda Club Philippines: http://www.hondaclub.com.ph/v4/home.php
For opinions on the best set. Try to search the net and club sites for a set of lowering springs that have low spring rates. Softer, "cosmetic" lowering springs will not destroy stock shocks as easily as "performance" lowering springs. This way, you won't have to spend extra on shocks.
