Results 1 to 9 of 9
- 103
November 1st, 2002 11:32 PM #1help naman guys, kaka-galing lang namin Batangas a week ago at napa-off road yung pickup namin.. nung nilinis namin the other day .. nagkaroon siya na maraming maliliit na scratches..possibly due to flying pebbles.. di naman malalim.. pero madami siya .. anu kayang possible solution para mawala? ... kakayanin kaya ng rubbing compound yun? knakabahan kasi ako eh .. saan kaya pede pagawa .. na mura naman .. pang-estudyanteng budget .. Salamat!
:wink:
- 121
November 2nd, 2002 12:43 AM #2Rubbing compound should be one of the last thing you should do, as it is the most aggressive on the paint.
Start with the least aggressive solution, then work your way down to the more aggressive ones.
Start with a little polish. Zymol HD Cleanse or One Grand Special Touch are both good products. Apply in a back and forth (or front to back) motion and see if manages to remove the scratches.
If that doesn't work, you can try products like Meguiars Scratch X.
If that doesn't work, then you can try the rubbing compound.
If that still doesn't work, the only other that you (personally I mean, not a body shop) can do is to attempt to apply touch up paint. I found this pretty difficult, and I've had numerous failures attempting this one.
Work in stages, so you don't mess up your paint even more.
If all else fails, take it to a reputable body shop and ask them what they can do.
Good luck!
November 4th, 2002 10:19 AM #4
renel, based on your description, you probably have the usual-dreaded hood and bumper stone chips from the road... unfortunately, you really have little recourse if the paint has already been chipped off...
NO COMPOUND WILL OF BE ANY USE IF THE PAINT ISN'T THERE...
Compounds and polishes are supposed to level the paint by thinning it to blend with the surrounding paint areas. If the paint isn't there, what's there to compound? None... You'll just thin out the paint areas that aren't even affected.
Oh, don't use TW Polishing Compound, it's crap.
November 21st, 2002 11:32 AM #5
sir theveed... i just recently got a new car... and it's color BLACK !!!!...
already i see multiple scratches along the hood and stuff...
how do i minimize this?
is it possible to remove the scratches at all?
- 121
November 21st, 2002 11:54 AM #6Originally Posted by need4speed
Apply polish to remove the existing swirl marks, and provide protection to your paint by applying a good layer of wax.
It isn't really that difficult to own and maintain a black car. It just needs a little bit more TLC than cars with a different color.
Good luck, and happy cleaning!
- 109
November 21st, 2002 02:28 PM #7Amen... Theveed...
black is a nightmare... ganda lang pag tapos mo nang linisin... :P
Hirap lang kasi ngayon, kakatamad, linis ka sa umaga, init ng araw...
by noon uulan na, tapos paguwi mo putik ulit...
Meron din akong mga scratches before, I tried 3M na polisher, very good...
November 21st, 2002 03:25 PM #8
I won't reiterate what e46 mentioned anymore, coz it's true... what I can tell you is that there's absolutely NO WAY to prevent micro scratches. Everytime you TOUCH your paint, you'll introduce a micro scratch or two... it only depends whether the scratch is obvious enough to be annoying...
Black is the worse color for hiding imperfections coz the contrast of light and a dark surface is immense, kita agad yan...
To further explain what e46 said about cleaning motion... Swirls are nothing more than circular scratches. But unlike linear scratches, they're visible at ANY angle...
Black black black... Your best bet is to keep the wax/sealant layers thick at all times... Wash if you're in doubt (of whether the surface is clean)... It's a lot of hard work... But surely, it is also the most stunning color to view when perfect.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
