yes, but you will have to find the correct set of springs to lower your Accord. But if you can't find a set that will lower your car to the desired results, the typical result is the rear hanging too low as compared to the front. A solution is to install "lifters" or spacers at the rear springs to lift it up 1/2 to 1 inch.
