Results 1 to 20 of 23
    May 2005
    Which is better ?
    or depende kung madaming curves ang ride mo?
    well, at the end of the day, it's the blade that'll be doing the work, so if you're not "barumbado" gumamit, I see no difference.
    May 2005
    Quote Originally Posted by theveed
    thanks sir dave , doon na lang siguro ako sa Jelly
    May 2005
    I use the original California Water Blade (made in usa) which I notice it makes lots of loud streaking noise when being used on the body (on the glass its quiet). I dont know if this would affect the paint surface......
    Quote Originally Posted by number001
    same here. .dont think it scratches my car though. . pag bagong wax naman, less ang squeak.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Oct 2005
    Quote Originally Posted by caloyski5
    It could be an indicator that your ride needs waxing Hmmmmm....good idea.
    Feb 2006
    Concorde greenhills is selling water blades... it's not the California brand. They're retailing it for P1,200. I just dunno if this is better or not.
    Apr 2006
    sir david where'd you get the rubber squeegee that you use in bigberts? thanks! it's the blue one i think! it's very effective to use before drying the car out. thanks!
    Nautilus: Mother's (Renault) sells them... Check the MOther's thread or the California Duster thread dito pre.
    Oct 2005
    Thanks THEVEED, you can also order from BIGBERTS.
    We got word that someone is selling or will sell imitation California Car duster or water blade . Please check before buying to assure Authenticity. Dont settle for anything less than the original California Car Duster and or water blade, might scratch up your RIDE(s).
    i definitely agree! harharhar
    Jun 2005
    i have the water blade and i dont remember hearing squeaks during use (i dont have wax on the cars, but acrylic based seal klasse). that sounds like friction, and bad for the paint right?
    meron bang user ng water and jelly blade? is the jelly design besides flexibility better? feedback please
    I have to wash the car everyday bec it rains everyday, sometimes twice pa nga during weekends. The Water Blade is so effective in fact it should be one of the most important arsenal an OC should carry in his car trunk especially in this tropical weather. It glides well especially on a well waxed car and it eliminates 95% of H2O from most surfaces. The squeeking or streaking sound happens only when there's little water left, or if there's water then there's little wax left, or simply because the blade is not used properly. I see it most effective when I bend the blade's T-bar edge almost parallel to the surface and just follow along the contour. The more curvaceous, the more I put pressure through the handle. It bends easily with minimal pressure, and it doesn't scratch at all unless the edge has a damage to it. When it pours heavily outside I do a quick whisking at the Mall parking lot and then dry it off with a waffle microfibre, all of this done under 5 minutes. Talk about OC behaviour . Yes there were curious eyes wondering how weird I may have looked, but my point is the blade is highly recommended when you want a quick drying method, beside the water sheeting exercise of course. Most efffective to pair it with the microfibre drying towel. Cheers.
    Are you guys 100% sure that the jelly/water blades doesn't cause any paint damage if used properly?
    The tool itself won't, just like MF towels, washmitts, etc... not being careful using it could induce paint damage, as with anything else.
    The only thing that won't damage paint is to not touch it or expose to UV anyway.
    Ah ok thanks... I guess I'll stick with my chamois using the slow drying technique (patong chamois, pull it out, repeat)... medyo konti na lang din naman yung tubig when used with your recommended water flow technique. :ahppy:
    Kailagan mo pa rin kasing i-follow-up ng chamois o MF. I dont think chamois is slow at all pero syempre iwan sa jelly/water blade.
    Pero parang delikado sa Mall(labas) kasi bago nabasa yan panay alikabok yan. So scratch yan. Kung mag-iingat ka talaga bago maulanan ma dusteran mo muna. Pagkatapos ng ulan(wala naman dalang alikabok ang ulan, maaaring tilamsik ng putik sa gilid), un pede mong i-dry.
    Kaya ako sa bahay na lang talaga after wash. Hindi naman tumitindi ang araw naun. Mas masama pa ang watermark kapag after shampoo na hindi tinuyo kesa dulot ng araw after a rain sa panahon naun.
Jelly or Water Blades????
