Page 26 of 34 FirstFirst ... 16222324252627282930 ... LastLast
Results 501 to 520 of 680
    #501
    Nasubukan kona yung Akemi and Pompanzi, similar gloss, and not scratch proof but scratch resistant naman. Sa case ng watermarks, yup, na form parin siya but pag na carwash madali matanggal yung trace ng watermarks. Napansin kolang pag oily ang hand kitang kita ang hand smudge.
    Dec 2017
    #502
    That's all true. Ceramic/Glass coating is simply another layer of clear coat that will last for 2 years. You will still have watermarks, swirls and scratches regardless. But, it will still preserve the original clear coat while giving you a super glossy finish.
    Oct 2003
    #503
    Plus one to this.
    Ung coated car namin, may waterspots na din due to our weather din here. Mmya uulan then aaraw ng matindi.
    Alam ko na sasabihin ng kapatid ko, akala ko ba naka-glass coat yan? Dapat walang watermarks ek, ek. Sabi ko nga dapat proper maintenance pa rin. Just today nakita ko may hairline scratch sa passenger side door mga 3 inches. Di talaga maiwasan. Hehe babalik ko lang doon sa shop if they can remedy it.
    Also planning to buy Gyeon's water spot remover. Will try that kung matanggal nga talaga hehe just spray, leave on for about 30secs then wipe off na.
    Aug 2017
    #504
    Quote Originally Posted by zechs View Post
    Plus one to this.
    I saw one water marks remover sa lazada mr squicky brand but not yet tried.
    Sent from my iPhone X using Tapatalk
    Oct 2003
    #505
    ^not sure if that is safe to use on a coated car.
    Dec 2017
    #506
    For waterspots on a ceramic/glass coating, I use Meguiars Ultimate Quik Detailer (G-14422).
    "Meguiars Ultimate Quik Detailer is a high lubricity formula that is safe on all types of paint, including clear coats, single stage paint, and ceramic clear coats."
    Meguiars Ultimate Quik Detailer, Meguiars quick detailer, Meguiars Ultimate Detailer
    Don't use other products which does not specify ceramic coating safe.
    Oct 2003
    #507
    Yes thats true that you should not use products that is not specified for coated vehicles. That's why I would go for a water spot remover from a glass coating brand itself.
    Although I guess some brands are safe to use like this megs ultimate qd or sonax brilliant shine detailer.
    Aug 2017
    #508
    I use C2 v3(Gtechniq) to maintain my ceramic coating.
    Nov 2017
    #509
    Hi folks, is there an accredited seller of CarPro products here in PH? I'm looking for products for maintaining the ceramic coating for my car, like the CarPro Reload Spray Sealant and CarPro Spotless. Suggestions for another product other than CarPro would be great too!
    Thanks!
    Oct 2003
    #510
    *jojopad,
    You have reseller of carpro products in olx, not sure if their line is extensive though.
    Another alternative brand is Gyeon which has a reseller here down south.
    Aug 2012
    #511
    According to Mike Philips of Meguiars USA, there is no need for "special" product for ceramic coating. All their products can work.
    If you think of coating as a second layer of clear coat, then any detailing product that is safe for your car paint is also safe for coating.
    Sent from my ASUS_X00DDA using Tapatalk
    Nov 2017
    #512
    Quote Originally Posted by red_one View Post
    That's good to hear! I do have Meguiar's Ultimate Quick Wax, I can perhaps use that as an extra protection for the ceramic coating. As mentioned from another post in this thread, Meguiar's Ultimate Quik Detailing can be used for removing those nasty water spots and other contaminants. All of these products are conveniently available at local stores.
    Nov 2017
    #513
    *jojopad,
    Thanks Zechs for the info! I'll check out your suggestion.
    Aug 2012
    #514
    One of the purpose of ceramic coating and any other paint coating is so that you don't need to wax the car anymore.
    Nov 2017
    #515
    Waxing is optional, at least that was the tip from a detailing shop I went to. I reckon it can provide extra protection especially on areas prone to road grime, prolonging the ceramic coating.
    quik wax? it probably wipes off easily [emoji848]
    Nov 2017
    #517
    I used it for another car for the past month. So far it lasted for a month. Not bad for a spray wax that's very convenient to use.
    Nov 2017
    #518
    *jojopad,
    Found this local distributor of CarPro products from CarPro | CarPro Distributors | CarPro Car Care Products
    CarPro PH
    Aug 2009
    #519
    What remedy do they apply to coated cars that have hairline scratches?
    Sent from my ASUS_Z00ED using Tsikot Forums mobile app
    Aug 2009
    #520
    Quote Originally Posted by Calistro View Post
    Answering my own query; Remove coating, treat as you would normally, apply back coating
Inputs needed: Glass Coating
