Results 11 to 16 of 16
November 13th, 2002 05:41 PM #11
mix 1 part kerosone and 3 parts water! shake, wet pranella with the mixture then wipe, follow it up with running water and then car shampoo, tapos wax! :D
November 13th, 2002 06:02 PM #12
namumuti nga pag kero ang ginamit mo....try nyo diesel...tapos bodywash mo agad...
November 16th, 2002 05:46 PM #13
paano kung parang ang tigas na nung asphalt? pwede kaya pilitin i-rub?
takot ako ksi baka maging malabo na yung paint or baka mabutas or sumthin pag kerosene..
san pwede makabili ng tar remover? ano brand ang ok and tested na?
thanks..
November 17th, 2002 12:11 AM #14
ako i use WD-40. yung matitigas na asphalt, spray-an ko ng WD-40, after a few second, gamitin ko nails ko, tanggal.
Signature
- 115
November 18th, 2002 10:02 AM #158) simpleng TAR remover lang yan.......i recommend 3M tar remover...daling gamitin and tanggal agad yung aspalto.....spray type sha kaya ok...... :wink: :wink:
November 18th, 2002 03:33 PM #16
Dragon: kung makapal yung tar, just let the tar remover melt it little by little, eventually the tar would be removed with little rubbing.
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
