Results 21 to 30 of 57
January 9th, 2005 08:34 PM #21
well, that's what I really want to do. 15" mags, 50 series tires, then soud-set-up just like my old liteace (if anyone remembers) na up to now is still a head turner whenever I use it du to it's sound system :D. just had the time to remove the orange cap sa rear signal light today, some minor cuts and scratches inflicted sa hands ko pero it's worth it when I removed it and changed the bulbs to bluish white. at least terno na front and rear signal lights ko na bluish white....:D
January 10th, 2005 01:18 PM #22
you might want to use 55 series tires instead of 50 series tires to ease the rough ride.
January 12th, 2005 08:14 PM #24Originally Posted by N3IL53N
January 12th, 2005 08:36 PM #25
Here's some nice AE111 rides from Toyota Club Philippines
January 22nd, 2005 10:21 AM #26Originally Posted by ghosthunter
January 22nd, 2005 12:30 PM #27when I removed it and changed the bulbs to bluish white. at least terno na front and rear signal lights ko na bluish white....
Thanks..
January 22nd, 2005 02:36 PM #28Originally Posted by N3IL53N
The corolla AE111 & AE101 share the same spring type so its not hard to find lowering springs for your corolla. You can see the examples of other AE111 that have been lowered above. Results are pretty good.
January 23rd, 2005 03:07 PM #30Originally Posted by gearspeed
Monk-owned R53
