Results 1 to 12 of 12
    Sep 2013
    Baguhan lang po ako alam ko po na after car wash ang wax and buff.Pero ano po ba tama at best result nito? wala po ako buffing machine, thanks po
    Aug 2012
    Quote Originally Posted by Ciz View Post
    For starters, read page 1 of Tamang OC thread. http://tsikot.com/forums/auto-painti...tenance-77542/
    Also, backread the Detailing thread. http://tsikot.com/forums/auto-painti...nued-3]-77808/
    Oct 2008
    apply as little wax as possible. to do this, put a little bit on the applicator, and spread it wide on the dry panel. you'll see a change from dry to something hazy, that's enough. no need to use a glob of wax. spread the haze/wax. if the applicator is not spreading haze, it's time to reload a bit of wax again.
    then do the finger swipe test if the wax is ready for buffing
    then buff to shine.
    it's tempting but don't use the wax & applicator to correct swirls
    Sep 2013
    Thanks po. So ang circular motion pala ng mga car wash shops mali?.
    Aug 2012
    Hindi mali ang circular. It depends on your preference lang. DA polishers uses random orbital motion, which is similar to manual hand waxing in circular motion.
    Aug 2012
    Mar 2004
    Also kung first time mo pa lang mag wax, make sure to apply and buff 1 section at a time. That way, kahit na nagkamali ka maglagay ng makapal na coat, it won't be too hard to buff off.
    Once you become proficient at applying thin coats, then you can safely proceed with waxing the whole car before buffing off.
    Another thing is -- if it's your first time to apply wax, it might be good to invest in some masking tape to mask off any exposed plastic moldings that your car has. Getting wax on the plastic molding may cause it to get white stains. Pero pag confident kana, you'll be able to apply wax while avoiding the plastic moldings.
    Apr 2009
    Quote Originally Posted by ess View Post
    +1 on this. Mamumuti yung plastic mouldings kapag nalagyan ng wax. I got carried away waxing, nalagyan yung plastic shroud sa may wiper area. I had to wash it off, then apply tire black. Buti ok naman kinalabasan.
    Mar 2004
    Quote Originally Posted by garfield_08 View Post
    Hahah... mukhang rite of passage ata ito.
    My first car was a AE92 corolla XL. And believe it or not, I applied turtle wax hard shell on the unpainted front and rear bumpers.
    Grabe... it took months before the whitish chalk film wore off.
    I read frequently that Peanut Butter can fix this daw. But I haven't tried. (Or rather, I'd prefer to avoid it than try it.)
    Apr 2012
    madali lang mag wax. apply mo lang using ung applicator pad at dapat manipis lang ang pahid. kapag medyo nag haze o namumuti na, swipe mo ng daliri. kapag malinis na dinaanan ng daliri mo pwede na punasan. for best results, dapat malinis yung paint surface na iwa-wax at na polish. kung wala kang buffing machine pwede naman by hand lang, medyo matagal nga lang at nakakapagod...
Pano po ba tamang pag wax and buff po?
