Results 11 to 12 of 12
- Aug 2012
- 2,767
December 2nd, 2014 09:08 PM #11To remove wax from plastic moldings, wipe with rubbing alcohol solution.
Fill a spray bottle with one part rubbing alcohol (e.g. Green Cross, or any brand you prefer) and two parts water. Spray the alcohol and water mixture on the plastic molding. Allow the alcohol mixture to soak in for about thirty minutes. This will soften the wax and make it easier to wipe away. Wipe the plastic molding with a clean towel until the molding is free of wax. Repeat the process to remove stubborn wax spots from the plastic.
December 2nd, 2014 09:30 PM #12
madali lang mag wax. apply mo lang using ung applicator pad at dapat manipis lang ang pahid. kapag medyo nag haze o namumuti na, swipe mo ng daliri. kapag malinis na dinaanan ng daliri mo pwede na punasan. for best results, dapat malinis yung paint surface na iwa-wax at na polish. kung wala kang buffing machine pwede naman by hand lang, medyo matagal nga lang at nakakapagod...
Hybrids and EV
