Results 1 to 8 of 8
May 22nd, 2008 09:12 AM #1
where can i buy the glitters that are being added to the paint prior to painting the car? how much po kaya?
May 22nd, 2008 12:15 PM #2
Bro hinahalo na yan sa pintura. Try asking the paint shop na lang. Sabihin mo yung sparkling or metallic na paint.
- Jan 2008
- 152
May 23rd, 2008 06:48 PM #4
pagkakaalam ko, yung ganyang paint, yung metallic talaga... hindi na kailangan halo. kasama sa siya dun.
May 24th, 2008 12:46 AM #5
Custom painting ang finishing will run you several thousands of pesos. The "glitter" finish requires special spraying equipment and special curing, plus you must add an additional clear coat. Expect no less than 200,000 pesos. Of course that will vary depending how much you wanna customized the job. Make sure you get a paint code in case you have to match the paint in the future( in case of scratch accident etc).
same here. i renew my LTO regs at the start of the year, while i renew my compre mid-year. some...
1st LTO renewal after 3 yr registration
