can i use nanosliq everyday? hindi ba masisira ang paint? i know wax hindi pede, kaya di pedeng gamitin nanoglos araw araw....
Thanks for the reply
if you mean nanosliq will decrease paint thickness, then no.
more contact = more chance to make swirlmarks. making sure everything is clean, your tools, the car, will minimize the damage
the cleaner the car, the easier it is to wash
I don't think that using NanoGloss or Sliq will harm or thins your car paint.
NAno sliq ,
I only use this one, every time I put a new layer of nano gloss, every 4 or 6 weeks.
DRY WASH aslo from MT
I use this for maintenance , every after car wash.
Wax cleaner
As the name states it strips light contaminants and some wax residue
I use this for paint prep.
Yes po safe ang nano sliq but for maintenance I rather use dry wash.
Sent from my ASUS_X00DDA using Tapatalk
I've read somewhere in this forum that you could dilute nanosliq with water to avoid streaks.
*sean-archer do you use NanoSliq din? I used kagabi yung small bottle, ubos for my sedan! pero cleaned all panels. Di ko lang alam if pwede din siya sa glass and lights.
Will dilute this din para medyo ma cover lahat ng parts ng car. medyo natipid na lower panels kasi sobrang konti nalang ng natira.
If you could try the other branded products, mas magiging okay ung experience nyo. Believe me.
Aside from NanoSliq, Microtex now has Quick Shine and After Wash in their line-up are they all the same?
NanoSliq ang huling coat.
Pure silicone lubricant main component.
Main purpose para dumulas at hindi kakapit ang dumi, alikabok, o putik.
Since concentrated silicone lubricant siya, kaya nag streaks. Ingatan hindi mahawaan ang windshield o wipers, mag streaks at chatter ito.
May na discover ako mas ok na gamit ng NanoSliq silicone lubricant, concentrate sa basahan at punasan sa door seals at hood weatherstrip. Pang protection sa pagtuyo sa araw, at pag dikit sa metal at langitngit.
Since water based na Silicone, mukhang hindi harmful sa rubber seals, hindi tulad ng spray based Silicone protectant na may harmful propelants at mahal pa.
I like the nano slick kasi pansin ko lang madali sya mag wear off compared sa regular wax lalo na kun panay ulan o carwash.
I don't have any basis but I use nanosliq QD once a week, then spray wax the next week. Nanosliq again for the 3rd week and so on.
