Originally Posted by
indiej
if you use a bug and tar remover, follow the instructions on the product label and disregard the method below.
tar/asphalt could be washed away with a mitt but sometimes stubborn enough to need long-play claying.
try this on one panel only, on the lower side for suspect tar contamination. can be done on tarred glass
wash (always with car shampoo) the test panel. spray kerosene on the panel. Gaas or Kerosene is less than 60 pesos per liter at the gasoline station. 1 liter is enough.
if those are tar or asphalt roughening the panel they would start to melt and you can rub them off easily with a cheap microfiber towel damp with kerosene after about 5-10 minutes
then immediately rinse the surrounding area with water, shampoo and rinse again.
feel and compare with other untreated panels. if this method proves effective, still be careful and test yet another spot til you get the hang of it.
i'd clay afterwards but kerosene softens paint so it's better to do the next steps a bit later.
what i do is wash the car, remove tar, wash again. Then clay, polish, seal 1-2 panels only.
if you can handle it, always try/test first before having others take a chunk off your budget.
