Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    #21
    ^^^ best results are achieved with a newly waxed surface and using de-ionized water. BUT with a relatively clean surface (just washed) and ordinary tap water almost 90-95% of the water can be removed. even when the car is washed using only water (no shampoo, when you just want to get rid of daily dust) this method still does helps a lot. less water droplets to wipe off means less time and effort to dry rhe car.
    btw, i prefer mf cloth over chamois. parang mas madali kasi, less force needed to move the cloth over the surface.
    Oct 2016
    #22
    Quote Originally Posted by benchman View Post
    kailan pa iyan huling na-waxed? parang walang wax kasi.
    More than a month or almost 2 months siguro
    Sent from my SM-G930F using Tsikot Forums mobile app
    #23
    Quote Originally Posted by jdm86 View Post
    your wax looks weak though, re-apply ka kaya. ano gamit mong wax?
    Oct 2016
    #24
    Nakalimutan ko na yung tatak na nakalagay sa mismong bottle pero liquid wax siya with carnauba. Kasama sa isang kit from Mitsubishi.
    Or possible din kaya na masyado ng contaminated yung paint surface?
    #25
    try mo nang gumamit ng ibang wax sir.
    and you may take your time reading here for tips; https://www.tsikot.com/forums/auto-p...tenance-77542/
    Oct 2016
    #26
    Naalala ko na Dia Plus something ata hahaha!
    Anyway sige salamat po sir!
    Oct 2016
    #27
    Anyone here uses Microtex Elitr Drying MF?
    Jun 2016
    #28
    I do. It works well but I tend to blow the water off away first to lessen the needed contact time between the towel and the paint. However, if an outlet is not available (condo parking, for example), I just try to gently pour water or host it off and let gravity (and the coating/wax) work to lessen the water that I'll need to wipe off.
    Dec 2014
    #29
    What is your drying method? What method do you prefer? And do you have some drying tips to share to the community?
    For me, I still use the traditional chamois though I am planning to use microfiber drying towel if I ever find one.
    Microfiber cloth + Mothers Speed Spray Wax.
    Nov 2017
    #30
    hello, I always use the products of the brand Mafra. They have several good products to dry your car!
    They are leaders in Italy and their products are very good. If you want, you can try it
    Dec 2017
    #31
    I use a powerful 600W leaf blower and a plush MF towel I bought from Lazada. First, I pat dry the whole car with the towel to absorb as much water as possible. Then, I use the blower while patting it dry with the towel (folded into a square). This way, it dries a lot faster rather than using the blower alone.
    I never wipe as I know it will cause the dreaded swirls! Lol! The advantage of the leaf blower is that it can push out all the trapped water from the car's tight corners and gaps. The disadvantage is that is too high pitched noisy. I have to use a protective ear muff to muzzle the noise.
    Where I bought the product:
    Leaf Blower:
    Lotus LPB6 6W Air Blower (Black) | Lazada PH
    Plush MF towel:
    AutoShine Car Care Wax Polishing Detailing Towels Car Washing Drying Towel Super Thick Plush Microfiber Car Cleaning Cloth Grey - intl | Lazada PH
    #32
    squeegee sa glass, blower then several mf.
    #33
    Quote Originally Posted by brushless View Post
    Leaf Blower:
    Plush MF towel:
    Basically we use the same method, different brand/make material.
    Bosch blower/vacuum, I bought in Oman when I'm still working there.
    Microtex Elite Large drying towel (60cm X 90 cm) bought from True Value
    Water drying method.
    Dec 2017
    #35
    I think it's difficult to achieve the water drying method. Some parts are left with water droplets so I still have to use towel or perhaps I just don't know the technique.
    Meron talaga maiiwan pero minimal na lang.
    Dec 2017
    #37
    I used to water dry my car. But, I got lazy and I just went straight ahead with the pat drying/leaf blower method. lol
    Dec 2017
    #38
    I washed my car yesterday and used this Microtex Elite which I bought also from True Value. Absorbs well when pat drying and covers a much bigger area than my previous towels.
    Thanks for the tip.
    Jan 2008
    #39
    Thanks for the tip.
    I use turtle wax and dry spray wax. Easy to dry using member's choice towel..
Drying Method
