wala di ko mahanap kung san yung butas ng washer bottle ko![]()
diluted shampoo or conditioner or car shampoo lang ang ginagamit ko.
dont use bareta na sabon, cos those small bits will clog the lines of your washer.
Di kaya harsh itong mga shampoo/dishwashing liquid na gamit nyo for our paint? Used one before on our white car, left some streaks on the paint...
sa windshield lang naman gagamitin eh sir.
if you wanna be safe, use car shampoos. kahit mapunta sa paint. wouldnt be harsh.
Yes, I do. I just restored the washer system of my car with new nozzles, hoses, cleaned out the reservoir and pump, aimed the nozzles properly. Washed the car after, kasi puno ng washer solution.
In some areas where it really gets cold, some reservoirs are heated, while some washer fluids are winterized to prevent icing.
Subukan ko nga ang baby shampoo.
Share ko lang, re: baradong nozzle. Nangyari na sa akin na nagbara ang nozzle dahil sa impurities or foreign objects mixed sa tubig. Nakakainis! Nangyaring bumara ito kung kelan pa naman pagtapos umulan at kailangan ko mag-wiper para alisin ang mud spray galing sa sasakyan na sinusundan ko tsaka walang tubig na lalabas sa nozzle. Ayun, smudgy yung windshield ko. Buti na lang di ako na-aksidente. Inis talaga! Kaya ngayon, I make it a point na gumamit ng pinong strainer tuwing maglalagay ng tubig sa reservoir.
You can clean the washer nozzles with a needle, and also aim them using the same needle while you're at it.
The newer nozzles with a slit in place of the pinhole can be adjusted using a razor blade or fine screwdrivers.
i also use dishwashing liquid.. few drops lang does the job..
i also used to clean the windows using RainX..medyo horror lang kasi nung pumatak sa pintura natunaw top coat.. kainis!![]()
dishwashing liquid din...ok pag umuulan...pero pag natuyo sa araw malagkit kaya wash na ng windshield pag-umaraw na...
I use car shampoo with water solution during the wet season. During summer, I just use water.
ung windshield washer ko ayaw sumirit o bumuga ng tubig??.. ano po kaya problem nun>?![]()
Might be barado nozzle tip mo,have it declogged by pin,sundutin you lang butas.If not there,check the hoses baka may mga leaks,again if not,pump motor na nya or wala tubig resovoir tank nya
In using washer solution, not yet decide pa ko,but thinking of Rain x by autogard,ito yung pinapahid lang sa glass once every month,available sa Ace,handyman,diy,etc.
