Results 1 to 17 of 17
    Oct 2007
    It seems to me that these cars have a tendency of loosing alignment when it comes to bumpers. Does this problem have a permanent fix? Where do you bring it to fix this problem? Nakakainis na kasi. Pumapangit yung kotse pag ganito. Recommend naman kayo kung ano dapat gawin and san pwede ipagawa.
    (East area if possible e.g. Marikina, Cainta, Cubao etc.)
    Apr 2006
    hinahayaan ko na lang
    Jul 2006
    The problem is that the models released there basically just have bumper covers and no real bumper (hard solid or collapsible material to absorb impact). Ang alam ko the mounting points of the Honda Civic bumpers are simple tabs on the corners, near the grille and at the bottom of the bumpers by the radiator support. So in that case the bumper covers have nothing to fall back to.
    Oct 2007
    So wala na ba tayong magagawa pa?
    iyong sa akin nilagyan lang ng panibagong washer nung nag palinis ako ng headlights. actually parang piso pa nga ginamit niya. nag drill lang siya tapos salpak kaya ayos na naman
    Aug 2006
    ganyan rin sa akin ung harap medyo nakalylay sakit ng Civic ata yan marami ako nakikita ganyan problema kasi when you look at the civic bumber hollow ciya unlike nung iba talagang may pinagkakapitan
    Oct 2007
    sabi nga nila. pati nga yung latero sabi wala daw sil magagawa. align lang daw ng align. ganun na lang.
    Aug 2007
    actually sakit na talga yan kahit sa mga eg. yng esi namin dati konting tama lng natatanggal kagad rear bumper, masama pag natanggal sya madalas nawawala na din yng clip kaya bili ka na naman. sa bwisit ko naghanap ako ng nut and bolt na kasukat nung clip. yun, hindi na ulit nalaglag. nyahaha...
    Oct 2007
    Quote Originally Posted by blue1108 View Post
    ano itsura nung nut and bolt? san ka nakabili? lumapat din ba nung naglagay k ng nut and bolt?
    Aug 2006
    Plastic lang ang bolt at sobrang lambot ng bumper ng Civic what i hate about it most is that when you have to change something such as horns kailangan ibaba kaya pag balik baka hindi na align
    Aug 2007
    mrn kse motorcycle shop malapit sa'min, dinala ko lng yng clip tpos nghanap and ako ng nut and bolt assembly na kasing laki ng clip. medyo mahirap nga lng ikabit kse susuot ka sa ilalim ng oto pra makabit mo pro ok nmn pgkatpos
    Oct 2007
    picture chong para palitan ko lahat ng clips ng Vti ko para d na laglagin yung bumper ko please. TIA
    yung sakin naman di bumabagsak. pero nagkakaroon ng gap talaga dun sa rear bumper.
    Oct 2007
    Quote Originally Posted by wrcastro_ph View Post
    That's the gap that I want to eliminate. Gusto ko lapat na lapat. Walang sabit ika nga. hehehe.
    Aug 2007
    sorry bro, iba na oto namin ngyn e. maliit lng yng nut and bolt na ginamit ko nun. if i remember correctly, mga half inch yng diameter nung ulo ng bolt tpos mga 1 inch lng sya kahaba. tpos ngtry na lng kmi ng mga nut na kasya. try mo sa mga motorcycle shops. usually kse madami sila mga nut and bolt na iba iba sizes...
    Jul 2006
    I guess there are two solutions, one is temporary:
    1. Affix the bumpers permanently or more firmly with the use of nuts and bolts. This, however, will not solve the added wear and tear on the joints that hold the bumper cover to the body itself.
    2. Get the actual bumpers (the actual solid material inside the bumper covers), install them and use them for support in tandem with the nuts and bolts fix above. This will prevent them from sagging, hopefully, if the bumpers are still in good shape. Otherwise getting a brand new or good used surplus is your next best solution.
    While you're at it fix the headlamps, horns, etc that all lie inside them or that can be accessed only with the bumper covers removed, to avoid unnecessary removal in the near future.
    Oct 2007
    Good thing it's just the rear bumper that I have a problem with.
The Ever Laglaging bumper of Honda 96-98 Vti's and Lxi's
