Page 27 of 83 FirstFirst ... 172324252627282930313777 ... LastLast
Results 521 to 540 of 1650
    Mar 2005
    #521
    Quote Originally Posted by madkatz View Post
    I have one from the US i don't know if its the same brand though, its also chenille mop type but my problem was the joint broke down, but where in SM did you see that? at the basement? i'll try to buy one and give it a quick review, im sure edwin will also be game about the idea, cleaning SUV's is really a PITA sometimes especially when we detailed the Exped
    Sa may SM north edsa sa basement yung may mga nag dedemo ng mga products around 600 pesos.
    Feb 2010
    #522
    Quote Originally Posted by Ginnova View Post
    I've been reading this thread for several weeks now trying to understand and digest every bit of info about detailing. This thread is very informative and a gold mine of information. I have a 3 year old black car and i only use OTC waxes to maintain it.Mukhang kailangan na ng major detail since medyo rough na yung paint especially the hood.
    I plan to clay the paint to remove the contaminants. Nakabili rin ako ng collinite 476s. I also have nano glos and sliq. Gusto ko rin sana tanggalin yung mga swirl marks. Plan to buy swirlx. pwede ba by hand lang ang swirlx. wala pa kasi ako machine. This is what i plan do this weekend up to monday.
    1. clay
    2 swirlx
    3. nano gloss
    4. collinite 476s
    5. nano sliq
    Sa mga guru's , pls advise kung tama po ba gagawin ko. I would like do it right the 1st time.
    how about sealant. ano ang recommended combo for 476s ( KSG o Carlack ?). If i use sealant , ano ang mauuna i-apply sa dalawa ( sealant o 476s ).
    Tried calling some shops that distributes/sells KSG and Carlack pero wala sila stock. Anybody here selling these items.kahit tingi lang...thanks in advance
    Hi!! SEALANT po muna bago WAX.......
    May 2008
    #523
    If you could drop by his place one time i'll let him show it to you, we use a very soft pressure washer to clean it, and we also need to asses the condition of the washmitt to check if its really the one causing the swirls
    Ok sige po. Will find time to drop by.
    Aug 2009
    #524
    Quote Originally Posted by jmpet626 View Post
    Alright i'll try to check it out later
    #525
    BROTHER AND SISTERS sino ang nagbebenta ng sealant gusto kung subukan ito. magkano po ba at saan pwedeng bumili. paano ang application.
    Feb 2010
    #526
    Quote Originally Posted by raine View Post
    si ate MADKATZ meroon....mura na sure na orig pa......
    good luck!!!
    kelan kaya ako makakapag seal.........ma txt nga master
    #527
    MADKATZ PLS kahit pm mo nalang price and place saan mabibili ang sealant
    #528
    *Raine, P1400 sa webiste ng carlack 500ML ito . I'm also shopping for a sealant. Baka gusto mo hati tayo sa 500ml. masyado na marami kung for personal use lang. pm me if you're interested.
    #529
    SwirlX could be used by hand, but there have been a lot of different reviews about the results obtained via hand application, machine application however produces uniformed and better results but again it does not mean that the same results cannot be achieved by hand, hand application of swirlX or any SMR's are totally dependent on application method, so if you could dial in on one system or style of hand application that you like you could do that to the rest of the vehicle, and as we've said if its by hand application we usually recommend going from the least to more aggressive method.
    Another alternative you could do is use 2x coating of Nano Glos to cover up the swirls before you apply 476, this way you fill in the swirls so its visually removed and the filling Nano Glos has, has a better durability compared to glazes so its stays there longer and can last more washes.
    The steps you mentioned is correct
    Carlack Long Life Sealant is a good sealant to be combined with 476, however you still get the maximum results of the sealant if you use the Carlack NSC to prep the paint to let it accept Carlack LLS properly, and then layering 476 after 24 hours is a great idea if gives you two of the best and most durable protection available from waxes and sealants
    My BF used to sell them in smaller repackaged quantities but i think he already stopped, try calling Big Berts i think they still have Carlack available.
    Ma'am madkatz, thanks for your replies. I'll take note of them.
    #530
    Ginnova saan mo nakita ang carlack? saan pwedeng bumili nito?
    Mar 2005
    #531
    Jul 2010
    #532
    guys, ano pwedeng iapply na dressing sa wheel wells after washing with shampoo? gusto ko sana maging black ng konti yung itsura ng wheel wells eh. pwede ba iapply dun yung microtex tire black o sunshield protectant or maybe tire foam to make it darker? black kasi kotse ko eh tapos brown-ish yung wheel wells dahil sa dumi. gusto ko sana lagyan ng dressing para maging black ng konti.
    Oct 2008
    #533
    try a spot about the size of your palm, let dry and see if it works for you. are you working on your car this early? good job.
    Jan 2010
    #534
    GUYS
    paki confirm lang po sakin to..
    collinite 915/476s can be applied by hand.?
    or much better if may device tayo gagamitin.?
    Jul 2006
    #535
    Quote Originally Posted by mada View Post
    GUYS
    Pde yan by hand sir. Just be sure na maganda prep ng paint mo bago mo iaaply.
    Feb 2010
    #536
    GUYS
    yes both waxes can be buffed by hand......1 lang gamitin mo IMHO pili ka lang... syempre masmaganda kung naka makina ka tulad ni matt ....
    pero kung gusto mo madali matutunan na makina..... mag unano ka......hay sana by dec makabili na ko nun.... anyway I strongly suggest pag unano gagamitin mo eh ke ate MADKATZ ka kumuha sabihin mo pa modify mo na rin..... napaka simple gamitin....nag cocorrect din siya pero iba pa rin yung mga malalaki.... mas easy to handle kasi unano....cute parang si MADKATZ.....[SIZE="2"]tulog pa master hehehehehe!![/SIZE]
    Jan 2010
    #537
    Quote Originally Posted by PSI View Post
    pero kung gusto mo madali matutunan na makina..... mag unano ka......hay sana by dec makabili na ko nun.... anyway I strongly suggest pag unano gagamitin mo eh ke ate MADKATZ ka kumuha sabihin mo pa modify mo na rin..... napaka simple gamitin....nag cocorrect din siya pero iba pa rin yung mga malalaki.... mas easy to handle kasi unano....cute parang si MADKATZ.....[SIZE=2]tulog pa master hehehehehe!![/SIZE]
    thanks....paging maam MADKATZ....you have a pm.
    Aug 2009
    #538
    Quote Originally Posted by air23 View Post
    I would suggest you clean the wheel wells as much as you can so the dressings can stick properly, actually what we do to our wheel wells is spray some de-greasers and let it sit for a while and then use a brush to clean it, be sure to turn the tires so its easier to clean, then let it thoroughly dry before you apply the protectant, all of the products you mentioned are good for that purpose but Microtex Tireblack has the best clinging ability and it also lasts a little longer, once you've done this its easier to subsequently clean the wheel wells since the dirt doesn't stick as much as compared to bare wheel wells without dressing
    Aug 2009
    #539
    GUYS
    yes its ok to apply by hand, and for me its still better by hand than machine, using a machine can ensure a uniform coverage but you end up wasting more, but you could also have the same results by hand with proper technique and thru getting used to it
    Aug 2009
    #540
    Haha you're crazy! Anyways sorry if you guys didn't push thru, i guess edwin got the flu from me, sorry guys i'll just reschedule the session again
Detailing Thread [For Newbies][continued]
