Results 1,651 to 1,660 of 2535
- Sep 2011
- 241
October 16th, 2014 09:30 AM #1651
Claying I believe will not only remove contaminants but also strip/remove most if not all sealants/waxes on your carpaint. So wala "protection" yung surface ng clearcoat/paint mo. I make sure na after ko mag clay either compund,polish,protect yung paint or clay/protect yung paint.
KAIO I believe has cleaners, di ko lang alam kung pwede mo siya isubstitute sa claying, yun nga lng malamang matatanggal yung M step 3 mo ni KAIO o nung repeat claying mo, sayang lng. The best route i believe with your products is clay, M step 2, KAIO, KSG, then LSP mo si M step 3
October 16th, 2014 10:42 AM #1652
- Sep 2011
- 241
October 16th, 2014 10:46 PM #1653Mother's step 2 is a polishing/glazing product and KSG I believe is a sealant. Step 2 will give your paint minimal to no protection. Di sya magcocompound so kung may mga swirl marks/defects kitang kita yan. Step 2 can hide those swirl marks but might not correct it. KSG and step 3 ang sigurong redundant but I like the shine that carnauba waxes give compared to sealants, but most sealants are more durable compared sa waxes. Pwede rin siguro after KAIO diretso na sya sa step 3 kaso sayang naman KSG niya.
- Oct 2008
- 213
October 17th, 2014 10:16 AM #1654Is it better to have a new car to be paint protected (like BB's new car paint protection) or wash and wax/seal regularly will suffice?
And if I go for paint protection, how long should it take before wax/seal can be applied?
Thanks..
October 17th, 2014 12:18 PM #1655
- Sep 2011
- 241
October 17th, 2014 08:26 PM #1656Wash and wax/seal will not remove all the contaminants in your new car ( I do believe na kahit bago pa yang car, I assume na naexpose na sya sa environment unless nakuha ko sya fresh from the factory ) so technically you will layer your sealant or wax on top of contaminants/pollution etc. That will compromise the looks and durability nung wax/sealant mo.
Ang ginagawa ng paint protection is to remove as much as possible all these contaminants so that immaculate yung clearcoat/paint surface mo, so that pagapply nung sealant/wax maprepreserve yung looks nung immaculate paint mo plus dadagdag pa niya yung depth/shine nung sealant/wax. Correct me if I am wrong pero pag may involved na correction ( swirl marks/defects removal) eh detailing na tawag?
Kaya nga yung iba therapeutic sa kanila pag dedetail ng sasakyan because they get some satisfaction/gratification on their work ;). Night and day panu difference pag maganda prep sa paint tapos papatungan mo ng sealant/wax ( IMHO except on a white paint unless sobrang napabayaaan) ;)
- Aug 2012
- 2,767
October 18th, 2014 09:22 AM #1657BB New Car Paint Protection (0-2 months old) = Premium Wash + Paint Claying + German Acrylic Paint Sealant
BB also has a year-round paint protection program named 'Optiguard' for new and old vehicles. It consists of 4 sessions which is 1 full exterior detailing session + 3 maintenance sessions.
Full exterior detailing = Premium Wash + Paint Claying + Paint Correction + German Acrylic Paint Pre-sealant + German Acrylic Paint Sealant.
i think this 'German Acrylic Paint Pre-sealant' refers to Klasse AIO while 'German Acrylic Paint Sealant' refers to Klasse High Gloss Sealant Glaze. as we all know, both products are acrylic-based and manufactured in Germany. please correct me if i am wrong.
- Oct 2008
- 213
November 11th, 2014 02:19 PM #1658Hi all,
What product can you recommend for maintaining plastic grills and chrome/plated parts? and is there any way to prevent headlights from yellowing? Thanks.
- Oct 2008
- 525
November 12th, 2014 10:33 AM #1659Guys, ok din ba yung ultimate filling system ng microtex?
1. NanoFIL
2. NanoSIL.
3. NanoGLOS
4. NanoSLIQ.
November 14th, 2014 03:04 PM #1660
use the same polishes/waxes/sealants for chrome plated parts
grills will benefit from anti-uv dressing. water spots is its main uglifier though.
thoroughly wipe it dry every wash and blast it with air to dry tight gaps or;
find out how to disassemble the part. it will look new again anytime with a spraycan of non-gloss black paint.
the headlight clear cover can be protected by applying sealant/wax with anti-uv or painted with clearcoat; inside to guard against UV from halogen/HID bulbs, outside, against UV from the sun.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
