Results 1,161 to 1,170 of 2535
- Aug 2008
- 965
June 4th, 2013 07:25 PM #1161I hope you don't mind me commenting on your regimen - just a few things I'd change, myself:
I'd probably skip the wash after the clay - since you're using a QD for lube, and will be polishing afterwards, the wash seems like an added step to me. I'd also not bother with Mom's step 1 - M105 will remove anything that step 1 will, as part of the polishing it does. Additionally, you're going to be using KAIO, which does just as good (if not better) a job at cleaning as Mom's 1 does.
I'd move the KAIO step just before the KSG one - they're made to work together, and there really shouldn't be anything applied in between the two. You particularly don't want an oily glaze like M7 under KSG - it will drastically impact the durability of the product. If you really want to use M7, I'd do if after the KSG layer (it won't strip KSG, since M7 doesn't have any cleaners).
So, if I were amending:
1. Full Wash
2. Clay then QD wipe
3. M105
4. KAIO
5. KSG (planning on 3 passes)
6. M7
7. 915
8. Sonax Brilliant Shine QD for maintenance
Fewer steps, and likely the same result.
- Jun 2004
- 1,311
June 4th, 2013 07:26 PM #1162Maliban ba sa mothers, ano pa available locally na clay bar? Meron ba cheaper alternatives?
- May 2005
- 341
- Aug 2008
- 965
June 4th, 2013 07:35 PM #1164If you're just getting the twins, and won't be able to avail of any free shipping offers, I'd consider getting the Werkstat products instead - they're based on the same formulas as the Klasse twins, but more advanced. Prime is the updated version of KAIO, Acrylic Jett is the equivalent to KSG. Also worth considering would be Acylic Jett Trigger, which is basically KSG in a sprayable form. Best part is, they're actually cheaper than the Klasse equivalents, and (excluding any sales) ship at a lower cost than they would from Autogeek, too.
- Aug 2008
- 965
June 4th, 2013 07:42 PM #1165I've seen Meguiar's claybar kits on sale as well, but at pretty much the same price. Han's Tools in Shangri-La offers DuPont clay, na clay lang - no QD or anything - but I think it was for 1,100, so not much of a savings there, either. Seen some Mother's kits on Sulit for slightly lower prices, might be worth looking into.
- Feb 2013
- 157
June 4th, 2013 08:57 PM #1166
June 4th, 2013 10:13 PM #1167
- Feb 2013
- 157
June 4th, 2013 10:16 PM #1168Checked it online. They are the makers of Carlack68 also. Think they're phasing out this line and replace it with what Sir Umi recommended.
Might try this out
June 4th, 2013 10:33 PM #1169
i fully agree with sir umi001, KAIO worked in synergy with KSG. i might even skip the M7 because its the same glaze and with the planned 3 passes of KSG, i think its a waste of detailing product and time.
and btw, 3 passes of KSG seemed to be that long to apply for me, considering a minimum curing time of 4 hours in between passes. the most application i had with KSG was 2 passes, that is waiting 8hrs in b/n as curing time. but if you have the luxury of time then that's not a problem.
a full wash > clay > m105 > kaio > ksg > 915 > qd in my opinion is good enough for the rainy season.
June 4th, 2013 10:45 PM #1170
Uy! BlackFire Wet Diamond. Pahingi sample!
Silky smooth ba yun paint afterwards? :naughty2:
San mo nabili?
Fire Extinguisher for Car: what brand and type...
