Originally Posted by
umi001
Rinsing will make it easier to remove the kerosene, go ahead.
A regular spray bottle will release too much product in on trigger pull. I'd go for a finger pump sprayer, with the caveat that if you don't evacuate the spray tube after use, the 845 can solidify and clog the line (you can evacuate the spray tube by inverting the sprayer bottle, then spraying anything left in the tube out). Also, make sure you use a PET or PVC plastic bottle, not a HDPE or LDPE bottle - the solvents in 845 leak through H/LDPE plastic.
