Results 811 to 820 of 2535
- Aug 2008
- 965
July 10th, 2012 11:32 PM #811I'd simplify things a little - you can go something like week 1 3M, week 2 NanoSliq, week 3 OCW, week 4 NanoSliq, then repeat. Heck, I'd have no problems going week 1 3M, week 2 and 3 Sliq, week 4 OCW, week 5 and 6 Sliq, then repeat - both the sealant and the wax should be durable enough for that.
Sent from my GT-P6800 using Tapatalk 2
- Feb 2012
- 41
July 12th, 2012 02:14 PM #812saan nakaka bili ng Klasse product???
meron ba sa Banawe? at how much?
- Aug 2008
- 965
July 12th, 2012 02:44 PM #813
- Aug 2011
- 171
July 12th, 2012 07:50 PM #814Thanks for this. My car had some watermarks due to the carwash done by the CASA when I had a change oil.
I washed my car again using ONR. Then applied OCW while car is still wet and dried it. Tama ba itong process na ito?
I noticed that there were still some watermarks left. So I guess ONR and OCW cannot remove these. I applied nanogloss in the watermark and removed some of them. I am not sure if it removed it or just hide it.
I guess I need cleaner wax or pre-cleaner wax muna for these watermarks before applying OCW.
- Aug 2008
- 965
July 13th, 2012 10:12 AM #815ONR washing doesn't leave a lot of solution on the panel, so it should be fine - though what you can do is do a first drying pass with one MF to get most of the water off the car, then spray OCW and finish drying afterwards.
ONR and OCW won't remove watermarks. NanoGlos has some cleaning ability, so it can remove some of it, but you're right - a proper cleaner wax or pre-wax cleaner would be a better option.
- Aug 2011
- 171
July 13th, 2012 11:39 PM #816Thanks again umi001...
I was able to remove most of the watermarks using ONR with QD strength... I read somewhere in these forums to start with the least abrasive method first in removing watermarks. I think there is only about 3-5 small dots left on my hood.So this means the next one which is the pre-cleaner wax. I went to blade/true value in park square and found meguires/mother's pre-cleaner wax/step1. Medyo pricey pala sila. Well, kasi malaki bote for aboth 500+ pesos.
Then since I am now paying attention to my paint, I noticed naman now na parang meron about 5 very small biloys. Parang sa clearcoat lang ang affected. Parang butas na kasing laki ng lang ng tuldok. Baka nalagyan ng alikabok nung nag-apply ng clearcoat ang factory? May solution ba dito o wag ko na lang pansinin?
July 16th, 2012 09:20 PM #817
good day mga sir, need ko lang po ng inputs niyo regarding po sa Turtle Wax Platinum Liquid Wax? and Turtle Wax Ice Liquid wax? ano mas better sa kanilang dalawa mga sir? ano po sa dalawa ung mas matagal matanggal? And pwede po ba patungan ng Mothers FX Spray wax ung Turtle Wax? Wala po kasi time para sa Mothers 3 step. Pasensya na po mga sir newbie palang po ako sa detailing. Thank you.
- Aug 2008
- 965
July 16th, 2012 09:30 PM #818I've not used the products, but based on everything I've read, I'd go for the Platinum wax (though probably the paste version, just because I'm partial to paste waxes myself
) - in fact I'm planning on adding TWPUG paste to my collection. The FX spray would be fine, though depending on the car color, the Reflections Spray Wax might be a better option.
July 16th, 2012 09:41 PM #819
Thank you sir for the quick reply, college student palang po ako kaya wala pong time pag detail ng mataggal. Any other brands sir na pwede gamitin instead of Turtle Wax? Ung isang apply lang po sana then wipe na agad, then patungan po ng Mothers FX Spray Wax. Color red po sir ung auto.
July 16th, 2012 10:16 PM #820
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
