Results 1,091 to 1,100 of 1575
December 9th, 2010 11:38 PM #1091
- you must still fully cure the first wax layer
- spray the ice cold distilled water on the panel
- apply the 2nd layer of wax
- buff after hazing
the cold water helps two-folds in preserving the first wax layer. It hardens the previous wax layer and it dilutes the solvent from the new wax being applied, lessening its dissolving effects on the first wax layer. This probably will work better these cold December dawns.
December 9th, 2010 11:43 PM #1092
December 9th, 2010 11:45 PM #1093
AFAIK, applicable lang ang spit shining sa carnauba-based wax, not sure though kung pwede sa mga synthetic polymer...
anyway, the principle is to "avoid" the wax's chemical (neutralize the solvents) to disturb, remove and/or mix with the existing layer of wax, thus, you use a "cold" (about to be frozen) distilled water or QD to mist the surface first before applying the new layer so the newly applied wax will almost freeze, then you wipe/buff it off until the wax and water (or QD) disappear...
it's a tedious process, and i'm not "satisfied" with its effect... i'd rather use the same product lines, as the manufacturers guarantee that their products "blend" well with each other... HTH...
December 9th, 2010 11:52 PM #1094
- Nov 2010
- 30
December 10th, 2010 12:08 AM #1095
- Aug 2009
- 1,553
December 10th, 2010 12:28 AM #1096
- Aug 2009
- 1,553
December 10th, 2010 12:29 AM #1097
- Aug 2009
- 1,553
December 10th, 2010 12:32 AM #1098i love that site and yes i would have to agree with their detailing forum being very active but i find that most members are fans of most detailing shops which i find the practices quite substandard compared to the US standards but then again thats just my 2 cents, im thinking of actually posting there but we already sold our FD hehe so i can't post pics of non FD details
- Aug 2009
- 1,553
December 10th, 2010 12:33 AM #1099
- Nov 2010
- 30
December 10th, 2010 06:13 AM #11008 hours! noted! thanks ma'm!
question, again, sorry if makulit po, after that given time, what if I need to use the car after applying the 476 and it rained and of course dirt came along the way and I'm not yet done putting the sealant (OCW) on top of it, will it degrade the last wax I've applied if I wash the car again?
Itong si Randz, parang si Scotty Kilmer.... highly opinionated. The C1 forward clutch drum,...
The Toyota Fortuner has landed (fortuner pics at...
