Results 1 to 20 of 1575
    Jun 2010
    Guys, naranasan niyo na ba maging mabalahibo(parang dust) ang MF niyo? Yung tipong pagkatapos magbuff ng wax, makikita mo naiiwan mga balahibo sa paint. Ano kaya cause nito? Mali kaya paglinis ko? What I do is, laba with perla sa washing machine, banlaw, spin dry, then sampay.
    Mar 2005
    Quote Originally Posted by kafph2000 View Post
    Pansin ko to sa Mga Plush at Ultra Plush na mga MF towel lalo na pagka dark yung color ng car. Parang yung fibers ng towel naiiwan.
    Jun 2010
    Quote Originally Posted by jmpet626 View Post
    Oo nga eh, black pa man din sakin. Kaya tuloy binabasa ko ulit. Plush ang gamit ko. Pano kaya masosolusyonan to?
    Jun 2007
    gamitan mo ng microtex duster... hehe
    Mar 2005
    Di na ko gumagamit ng Ultra Plush or plush sa pang buffoff ng wax. Gamit ko na lang yung Yellow MF's from SNR na naka 36 pack.
    Jun 2010
    Yan ung Pro-Force na brand sa SnR??? Hindi ba cya swirl inducing? I'm thinking of getting this na lang kasi mahal microtex...
    Mar 2005
    Quote Originally Posted by rico_g View Post
    Yung color yellow sya na 16x16 towels.Eto na gami ko pang buff off ng wax no swirls so far at walang naiiwang fibers unlike sa plush na may naiiwan pa. SInce mura lang siya madaling palitan pag nanigas na yung fibers.
    Aug 2009
    Actually for removing waxes and sealants, basically anything that doesn't need pressure to remove, those MF's area already great, but try to use those MF's to remove gummed on polishes and compounds and you will see it will actually instill scratches, those MF's are ok for light pressure usage but with moderate you might be a little bit disappointed, thats why we have a lot of MF's at home depending on the purpose of use, for QD and easy wax removals those are fine, but there's also a reason why we invest on the much more expensive MF's from Microtex and from abroad, BMW and mercs clear coat are very sensitive and believe me the MF's we use for them are very expensive hehe
    Mar 2005
    Quote Originally Posted by madkatz View Post
    Di ko pa na try mag remove ng gummed up polish using that MF. If applied properly yung wax and polish its ok naman. Nasa 35 pesos lang kasi lumalabas each yung yellow Mfs kung 36-pack binili.
    Aug 2009
    in most cases where the wax and polish is easy to remove and apply this is already enough, but with some of the Megs and Menzerna line same with Farecla they have a high tendency to gum up on high speeds with rotary and these gummed up products are usually very hard to remove often requiring a lot of elbow grease
    Aug 2009
    well with our MF's what we do is we have a dedicated washing machine for MF towels since we go through a lot of them if a detail session or a detail gathering with our friends happen, this way we don't get lint and fibers of cotton from other clothings into the MF cloth and we also don't get chemicals and polishes in our clothes, i remember before i accidentally threw a collinite applicator pad in the washing machine and our clothes ended up smelling like wax, so since then we opted to separate them, the stuffs you see might be a cross contamination from older wash loads, if its just a few pieces like 4 or 5 what i would do is just hand wash them on a separate pale and air dry after, this way no mixing of dust, chemical fibers and etc
Detailing Thread [For Newbies][continued 2]
