was going through my saved pages of this thread earlier before hitting the sack then some Qs came to mind regarding my last detailing session:
1. I noticed that when I applied Moms Back to Black on my tires, I got the wet look I wanted. I figured, maybe I'd put Moms Protector as well (I was thinking somewhere around the lines of carnauba over sealant...) but the wet look turned into matte finish... is it just me or was this to be expected? If it was supposed to happen, then I guess it was a waste of product AND time applying the Protector over the Back to Black.
2. I can't remember where I read it but before I forget the ask again is Moms S&G really not a sealant per se? If it is then should I have waited for some time before topping it with carnauba? What I actually did was S&G, Carnauba (2x), Spray Wax with just the 2 coats of Carnauba having a reasonably longer interval between coats, the rest went on top of the previous product as soon as I was done applying the previous product on the entire car.
3. IN the event that Moms S&G IS not a sealant, which of the following Megs would be better, the Polymer (#20) or Synthetic (#21) sealant?
4. When reapplying Sealants is it necessary to do the clay (I guess Dehadista would say... "It never hurts to clay" ;-D), cleaner and polish ritual again?
5. I had my center console and door handles trims sprayed (I'm not quite sure whether the shop used 2K on it-- is there anyway to tell?), how should I maintain these finishes IF needed (i.e. do I have to detail away at it like I would on my external finish?)
TIA.
