Results 1,231 to 1,240 of 5910
September 14th, 2005 01:27 PM #1231
Originally Posted by stubby
September 14th, 2005 01:32 PM #1232
I think you can buy Megs # 66 in repackaged bottles, its more practical, I don't know how long it will take to finish a whole gallon of polisher/wax unless you do this for a living
September 14th, 2005 01:48 PM #1233
Unless you can finish up the gallon fast, I dont recommend getting a gallon as madaling maghiwalay yung product and if the mixture is incorrect, di na sya pwede gamitin.
To Stubby: I believe may review ng Bosch sa PAD.
- Jun 2005
- 247
September 14th, 2005 03:51 PM #1234megs 66 it is then. i planned on getting a gallon kasi mas tipid nga, kaso as theveed said kung naghihiwalay pala eh di hindi rin pala pwede for the long run. i guess its best to check out those in repackaged bottles na lang, but im sure it will cost a little more.
tanong ko lang po, which has better cleaning properties, megs 66 or moms cleaner wax? coz i plan to top which ever is better between the two with rainhop habang tag-ulan.
btw, rainhop really beads and protects the surface well! 2 days after i applied rainhop, i gave my car a light water shower kasi may dust and dirt accumulation. after the hosedown, nakita ko na parang nakalutang yung water droplets sa surface! then when i wiped them droplets off, konting hawi lang nung microtex chamois tuyo na agad! will definitely be using this habang tag-ulan!
theveed, i knew of the bosch GEX150AC thru PAD. there's this topic re a review on this tool using DACP. ganda naman daw gimitin according to the user.
ess, glad to be of help!
- Jun 2005
- 247
September 14th, 2005 04:22 PM #1236noted po. thanks theveed. question olet po....when applying megs 66 with an ROP, do i do it like irmscher did in his PAD bosch review using DACP?
also, baka merong nagbebenta ng CCD...really need one!
- Feb 2005
- 157
September 14th, 2005 09:54 PM #1237still have one pero di ko mahanap yung bag... sealed pa ito kaso wala lang yung bag na kasama nito
September 14th, 2005 10:06 PM #1238
pretty much, yes.
btw, the microtex elite (waffle weave) will be out by the end of the month
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
