Results 201 to 210 of 5910
May 18th, 2005 11:29 PM #201
dehadista,
yeah lahat hand applied lang. what motion should i use? circular? sa EO kasi naka-indicate sa likod na cirucular lang eh..so i guess i should follow that? and by discernable you mean, if i see any changes right?
May 18th, 2005 11:35 PM #202
ako pedeng sit in student? irreg student? hehehe
the thing is i had nothing better to do last week so instead of sitting in the office i went outside and used some products scattered around. hehehe natuwa ako to see the car "semi" shiny. semi lang mali ata ginawa ko. anyhoo, question, is it possible to ruin the car's finish pag nagkamali sa pag detail or whatever? is there such thing?
now we have this Zymol in the office it says "detail"...hmm ano yun?
u guys were right this is fun! (kapagod nga lang) anyway, experiment ko na sa auto ko before having it re-painted. hehehe para kung magkamali at magkaiba iba ng shade okay lang. Lolz.
May 18th, 2005 11:39 PM #203
tsinita,
QD ata yung zymol na sinasabi mo..so quick detailing siya..spray and wipe siya onto a clean car..(oh boy, i hope my tip is right!) hehe di pa naman kami guru ni patopig dito hehehe
May 18th, 2005 11:39 PM #204
Originally Posted by patopig
IMO, try to get something with variable speed so you can also do polishing with mild abrasives and work on surface defects.. DeWalt, Bosch and Porter Cable come to mind...
patopig: black kasi kaya clear yung reflection-pic.. hehehethanks for the compliment.
when doing the 6 yr. old car, you might have to polish that out too in order to get the most out of that paint. also, clay mo na kagad after washing to remove surface contaminants.
May 18th, 2005 11:47 PM #205
Haha. 3 na pala kaming detailing padawan (sorry I couldn't resist since its star wars week :D)
Thanks for the tips again Master Dehadista!
Zechs and tsinita, good luck uli satin! Post tayo lahat ng before and after pics! hehehehe. Sana maabot din natin yung mga skills nila Dehadista, ILD, BM at theveed. hehehehe!
May 18th, 2005 11:56 PM #206
ahh oki oki.. now i tried it on my dad's pick up. i sprayed it, counted 10 seconds then i wiped it off,,,,baket ganun..parang it didn't have any changes ahahaha!
before and after pics ko ata parang the same lang. ahahaha i think i wasted products here. ahahaha
sensha na. natuwa lang ako i-try kase with all the stuff i've been reading here. kaya naten yan fellow padawans. the force is with us. (sino manonood bukas?)
May 18th, 2005 11:56 PM #207
Originally Posted by zechs
yup. see if there are any improvements. if the results are not to your satisfaction,
a) you might need a machine to step up on the work (kakapagod kasi pag hand) hehe
b) cleaner wax isn't enough. (meaning you have to step up on the product)
with regards to motion and marring-wise, may factor din kasi on what kind of applicator you're using.. foam applicators, MF's... try wrapping a MF around a good peice of foam and work with that.
BTW, sayang sana may clay.. removes a lot of those contaminants talaga.
tsinita: I'll be watching Star Wars tom.. heheheLast edited by chain; May 19th, 2005 at 09:37 AM.
May 19th, 2005 12:05 AM #208
dehadista,
is the foam applicator that comes with the EO cleaner wax any good? i would be using that. hirap maghanap ng murang foam applicators eh..what i see and bought (a value pack of 3) is sponge-like block.
OT: i changed my avatar nga eh..in lieu of star wars episode 3...hehehe did you guys watch the star wars clone wars kanina on the cartoon network? volume 1 and volume 2 ang pinalabas nila eh..sayang di ko naumpisahan..
May 19th, 2005 12:31 AM #209
zechs: tried it before, but that was during the time I wasn't using the applicator pads from Megs..
try this, if the foam feels rough against your hand, chances are, it's gonna introduce marring to your finish. cleaner waxes are chemical cleaners so it shoudn't be abrasive. it should remove minor oxidation and the like.
when in doubt, wrap some MF around it just to make sure.
- May 2005
- 3
May 19th, 2005 12:31 AM #210ey guys,
question about applying multiple coats of wax, what's the minimum curing time between each application? and how do you get rid of the dirt between each application, do i need to wash the car again?
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
