Quote Originally Posted by golti View Post
kailangan ba patuyuin yung nano-glos before i-buff? i tried it on my dad's car hoping to conceal the swirls.... apply using the straight line method then buff off after 5 mins... andun parin yung swirls... or masyado na malala yung swirls para sa nanoglos pag ganun?
NO!!! hahahaha well theoretically it should be left to dry, but i've always had problems with that wax if i leave it too long to dry, its a lot harder to remove once its dry pretty much like collinite, so what i do is wipe on wipe off, either that or when you're waxing try putting in under the sun for some reason that wax loves heat and becomes a lot easier to remove when its a little hot, but then again its not always a good idea to bake the paint and wax under the sun so my suggestion is just stick with the WOWO, there are really some swirls that can't be removed by Nano Glos, if thats the case then its already a bit too deep.
