Page 180 of 296 FirstFirst ... 80130170176177178179180181182183184190230280 ... LastLast
Results 3,581 to 3,600 of 5910
    #3581
    *Chikselog: Yes they have Carlack LLS, its around 1.4 to 1.6k i think? The M20 has very light cleaners but not as good as Step 1, if thats what you are asking. The Carlack LLS is a pure sealant and it does not contain any cleaners.
    If you are going to use it, it should be Step 2, LLS and then Step 3. But i guess it might give you some bonding issues though since the Step 2 has some oils in it and this might cause LLS to not bond properly to the paint. If you want to apply a sealant on your car, you could do 2 things
    1. Apply Step 2 as you normally would, do a 50/50 IPA wipe down ( just dilute 50% Isopropyl Alcohol with 50% Distilled Water, spray it to the paint panel by panel and wipe it dry ) to remove the oils, it will still give you that extra gloss from Step 2 and the added filling properties, this just removes the oils, then apply LLS, wait for 24 hours to cure properly ( its important not to drive the car around so you don't have to re-wash ) then do a QD wipe down to clean the car and apply the wax.
    2. Apply Step 2, Get the Carlack NSC instead ( it also offers a nice gloss but has a little less durability than the LLS but still good ) and then go directly to Step 3.
    I see..Carlack 68 ba yung LLS? Again thanks again for your inputs .. Ang galing nung 50/50 IPA method to remove the oils from some waxes..:2thumbsup:
    As of now I'm deciding pa kasi kung ano talaga bibilhin ko.. I want to protect the car from the heat and also as early as now nasa isip ko na kung paanong mas ma-protect pa yung paint come rainy season..
    As for Degreasers, Simple Green MAX is good, I use Mark V Degreaser as well as a degreaser i bought via carbouy locally and both works well, though i have Megs and other products i just save them for euro cars but honestly its all the same for me, it all boils down to concentration actually. What i normally do is spray kerosene and let it sit for about 2 minutes and then re-spray the wheel wells, and then wait for 3 to 5 minutes depending on when i see the asphalt melt and drip down. The thats the time i spray the degreaser to remove the kerosene and then soak the grime up for about another 5 minutes before i use a extended handle brush and work the grime out. I finish it up with either dressings or cleaner waxes, depending on the surface of thewheel wells.
    I see.. I'm gonna try this one.. Nung una ko kasing asphalt removal sa paint pati sa wheel wells sobrang takot ako sa pag spray ko ng kerosene, mga 30 seconds lang ata tapos nilagyan ko na ng dishwashing liquid..
    Yung Simple Green MAX ba ok din gamitin sa mga exterior plastic black trims? Specifically wax stains in black trims and also restoration na rin para magmukhang bago ulit like the trim below the wiper blades.. Conservative kasi ako hehehe, baka sakaling pupwede rin gamitin..
    Jan 2010
    #3582
    Quote Originally Posted by madkatz View Post
    *mada: QD's are generally used for cleaning the paint, whether for using it to clean contaminants like Tree Saps and Bird Droppings before it etches into the paint or simply for removing light dusts and giving it that newly detailed look. QD's are generally used on a dry surface and personally i use after i wash my car when im not waxing, if im waxing i use it after the waxing stage. You could use QD's for after washing just to add gloss but it does not offer any real protection. As for your Eagle One question, it would depend on what product you bought, is it the Wax As You Dry? Wipe and Shine?
    thanks for the info madkatz...
    for eagle one question.. yes wax as you dry nabili ko..parang hindi QD to. nagkamali ata ako ng bili.
    #3583
    Quote Originally Posted by mada View Post
    Ok lang yan sir..Mas maganda pa nga gamitin yan after washing dahil kahit papaano ay may wax yan.. Though it doesn't offer long term protection, it's still good to apply it after washing the car..
    Ang QD sobrang konting protection lang ang inooffer, well, most of them..And it's really not meant to serve as a protection for your paint..
    #3584
    madkatz, nakuha ko na si King (yung Tucson) ano pwede kong gawin sa paint nya sa ngayon?
    pwede ko na ba agad tirahin from clay to top coat?
    Silky Bronze FTW :clap: :clap:
    Mar 2005
    #3585
    *Starex_Gold
    Kahit wag mo muna i clay yan since bago pa. Ako nung nakuha ko ung akin derecho wax na ako.
    #3586
    jmpet hindi ko na sya na clay, step 2 agad. tapos step 3 + top coat later :clap:
    napagawa mo na yung dent ng Tucson mo?
    Mar 2005
    #3587
    Yup derecho na. Di ko pa nga napapagawa gamit parati eh. Sasabay ko na lang sa next PMS niya.
    Jan 2010
    #3588
    *Chikselog....diba di dapat mag wax all the time? kakatamad kasi ang tagal mong matapos...sabi ng iba wax once or twice a month, so yung spray wax nalang between those two kasi mas madali...nice idea?
    need to buy that QD...sa nababasa ko kasi ang daming purpose yan.
    #3589
    Natapos na ako mag detail
    wash>step2>step3>top coat
    #3590
    Mar 2005
    #3591
    *SG
    Nice. Premium variant yung sayo?
    Mar 2005
    #3592
    double post
    #3593
    jmpet, yes bro premium sya
    #3594
    Salamin ba yan ? hehehehehe
    Dec 2003
    #3595
    If I rub a painted surface with polish and the applicator/cloth comes out colored, I'm dealing with no clear coat right? I'm removing watermarks from my Adventure's window sills/jamb (the black part) and I'm concerned that I might wear it out.
    #3596
    Quote Originally Posted by RustyXIII View Post
    Yes sir.. Ano po bang polish ang gamit ninyo?
    Suggest ko sir if you're dealing with watermarks sa glass surfaces, use Elevo watermark remover.. Very effective.. Haven't tried on non-glass surfaces eh..
    #3597
    I also use Elevo watermark remover and as what Chikselog said, it is effective.
    #3598
    Galit!! Hehehe.. Congrats sir SG.. As always, ang kintab! Ginamitan nyo pa po ba ng QD after Topcoat?
    BTW how's the ride sir? Di po ba matagtag? naka 18s eh hehe..
    #3599
    hindi na ako nag lagay ng QD
    actually, matagtag sya sa ngayon. sana medyo magbago pa
    pero mas matagtag yung CR-V
    Mar 2005
    #3600
    Baka mataas pa yung hangin nyan nung nakuha yung tucson namin nasa 50psi pa siya.
