Results 3,461 to 3,470 of 5910
- Aug 2009
- 1,553
March 3rd, 2010 01:57 AM #3461*chickselog: sealant are very much liquid in consistency, more liquid that liquid waxes, they are very easy to spread, but the thing is its usually clear so sometimes its actually hard to tell if you still have some products or if you are still spreading the product.
- Aug 2009
- 1,553
March 3rd, 2010 02:06 AM #3462I just got myself a BnD Blower for 3400, its a bit cheap compared to buying it from popular hardwares. I opted for the BnD since the Makita blower is also made in china and because basically they both have the same motor, and the Makita would cost me around 1k more. I have to say im very happy using it to dry creases and those hard to reach areas, i wouldn't recommend you use this to dry down the whole car though, i tried it and noticed that if you use this to dry the whole car, its not as glossy as compared to being dried using MF cloth, and at times if water comes out from creases its a little dusty so it dries out with dusts pushed out by water from creases. But overall im happy, now i just wipe the majority of the area with MF cloth, blow the edges and creases, rewipe the areas where dusts and dirt comes out especially in doors creases and from inside the side mirror, for those hard to reach area's i just blow it off and it dries nicely.
Another use for this thing, that i thought of and worked quite well was that you could just it to remove a huge part of the dust from your car, since its very dirty here i tried it a while ago and a majority of the dusts came right off, so i guess that means less dusts for the duster meaning longer lifespan for my duster.
March 3rd, 2010 03:33 PM #3463
another question again for GURUS
Is the Megs 82 better than the Swirl X? or is it just the same?
sorry if this was already asked before...
TIA
March 3rd, 2010 03:56 PM #3464
Mas Agressive yung Swirl X. Depende sa severity ng swirls.
http://craigdt.web.officelive.com/im...rasives2.2.jpgLast edited by jmpet626; March 3rd, 2010 at 04:04 PM.
March 3rd, 2010 04:49 PM #3465
Tsikot Member Rank 3
- Mar 2004
- 2,053
March 3rd, 2010 05:31 PM #3466Well... yes and no.
When a product is more aggressive, it means that it will remove more paint using the same level of effort.
If your paint is severely marred, then maybe a more aggressive product will be more effective.
But if your paint's condition is not that bad, then using a more aggressive product will still work, but you'll end up removing more paint than what is needed.
March 3rd, 2010 06:10 PM #3467
March 3rd, 2010 06:41 PM #3468
Ahh I see then....so can I say... Swirl X= too much swirls & paint defects and Megs 20=for not to much swirls and paint defects?
sorry for keeping the language to my level...hehe...its just that I'm not too familiar with the terms being used in this thread........like moments ago, I just realized that the PC 7424xp is a machine buffer and not a wax...
thanks guys for the inputs...
March 3rd, 2010 07:13 PM #3469
Yung Swirl X uses SMAT (Super Micro Abrasives Technology) and yung 82 ata uses DAT (Diminishing Abrasives Technology)
http://www.autogeekonline.net/forum/...-products.html
March 3rd, 2010 08:26 PM #3470
At first glance, the answer would appear to be a yes. But in the real world, it really depends. Apart from the product, we have to also consider other factors, such as the paint itself, your choice of machine, polishing speed, pad construction, pad size, and pressure.
In other words, perform a test spot. That will greatly help in determining whether or not your product and pad combo would work on the defects of your car's paint.
Try to read this article from the MeguiarsOnline forum:
Let's talk about "Total Cut"
No worries. Ask away. Members would be here to help. That's what this forum is for.
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
