Results 11 to 20 of 27
March 27th, 2006 05:47 PM #11
IMO you can get the same result with proper detailing techniques and using the right tools. But then if it works for you then good :D.
SiRaNeko
- Jan 2003
- 973
March 28th, 2006 10:49 AM #13
I did apply QD right after i wipe off a part. It does dry up the surface kaya kailangan i-moisturize kaagad with sealant or glaze. Mas makintad pa sana yan if i have a polisher but wala e. Tsaka pag pinahiran ko konting punas lang. There's a spot na natuluan and mas maputi pa yun part na yun so don't let the degreaser dry on your paint.
Pareho pala yun effect when i used Tar remover before pero mas madali gawin ito. Parang ineerase mo lang yun dumi sa pintura.
March 28th, 2006 11:44 AM #14
bro, a sealant doesn't moisturize a car's paint.
while I do applaud your resourcefulness, yes, using a diluted APC will strip the car of all of its dirt, grime but also the protective wax and oils. Often times, a QD wouldn't suffice.
you mentioned slapping on wax afterwards. I hope you used something like a cleaner wax or even Megs Gold Class because these are something that would contain even just a minute amount of polish that would restore the oil that was removed from the paint. (that's why I mentioned in an earlier post that a good thing to do is to rub in a pure polish afterwards)
anyway, hope this helps.
March 28th, 2006 12:09 PM #15
I guess moisturize is the wrong word. More like bringing the shine back. Yun QD kasi parang oily e so that's what i used after. Hirap kasi tangalin nung wax kaya di ko na ginawa. Although the haze can be easily removed with a wet MF towel. Anu brand meron yun pure polish?
April 1st, 2006 03:49 PM #17
Here's the finish product. This was without claying, waxing, and I didn't use a polisher. The degreaser was P100 and the QD was the blue Zymol which is also P100. I used one P30 make up sponge and a P15 towel. So all in all mga P250 lang nagastos ko and 2:30hours of labor. This is a 10 year old paint. If you want to the convential way of getting a mirror finish then go ahead and visit the detailing thread.
April 1st, 2006 10:44 PM #20
hmmm...pwede...250 for that shine...not bad for a 10 year old white paint.
Automatic po Sir
