Results 11 to 13 of 13
May 26th, 2012 03:46 AM #11
^^That's one of the problem. You don't want water to sit and evaporate. They should water blade: hood, roof, trunk and windows. Use compress air to remove the remaining water ASAP. Then finish of with a quality micro fiber. A fresh set of micro fiber towels should be used on each step when needed. Ask how many cars they had dried with the 2 chamois before yours that day. Might as well use sand paper to dry your car.
- Mar 2011
- 70
May 26th, 2012 11:36 AM #12Kapag bago ang sasakyan ay hindi protektado ang paint....dip coating ANG NEW CAR......kapag pinunasan mo ay talagang magkakaroon ng swirl marks dahil ang dust and other grimes come in between the basahan at yung paint kaya microscopically parang dust and grime ang pinangpupunas mo...kung baga walang slide effect. Ang paint protection ay chemical film na binabalot ang buong paint cover mo pero kailangan ay marunong mag apply dahil delikado rin naman ang application kung may presence na ng dust and grimes na nag stick na sa pAINT MO. Sa dent studio na pinagagawaan ng sasakyan ko mahusay ang mga crew at alam nila ang lahat ng procedure....recommended to ng PGA sa akin para sa kotse ko...nasa 31 examiner st. sa west triangle qc....nag de dent repair sila pero dahil sa quality conscious da best din ang repainting at detailing nila. Try mo free estimate naman......
- Sep 2011
- 769
high idle RPM at engine start
