Results 1 to 15 of 15
    Oct 2013
    Hi
    Is there a way to easily remove this?
    Thanks!
    Sent from my RMX1971 using Tapatalk
    Sep 2006
    Can't seem to figure out what I'm looking, paint ba yung nabakbak?
    Quote Originally Posted by misterioman View Post
    Hi
    Thanks!
    prepare the entire surface for re-painting.
    my guess is,
    either the surface wasn't adequately prepared when it was painted,
    or the paint used was incompatible with what was already there.
    what do you know of its paint history, po?
    Oct 2013
    It's a fiber sticker na plain mga boss.
    Removing a Vinyl Wrap - YouTube
    parang foil-a-car or vinyl wrap?
    it should not be that difficult, but needs some tiyaga. lookit youtube.
    if you wish, you can bring it to the shop that applied it and let them do it.
    but my confusion is,
    why is it coming off in fragments?
    the fiber sticker i know, is applied as a sheet, and when it is time to remove it, it still comes off as a sheet. again, lookit youtube.
    is yours a low-quality product? is it the result of noontime sun degeneration?
    your underlying surface looks, beg pardon, hideous.
    the usual underlying surface of a removed fiber sticker is what the original surface was like...
    will some adhesive and remnants removal restore the smooth surface?
    good luck.
    i still can't help but suspect that yours might be a poorly-applied paint job.
    from the pics parang walang primer or pintura. parang deresto sa bakal in-apply yung sticker? or kasamang natuklap yun paint underneath ?
    puede rin.
    ayaw gumastos ng glossy paint job, kaya derechong pinatong yung sticker.
    that might also explain why it is stripping off. the product may not have been designed to stick to a non-glossy painted surface.
    It's not much different from window tint...2decade old 3M DIYremoved using heat. No residual adhesive & no partial panel tears.
    Aug 2017
    Hi
    Try soaking it with a lot of WD40 and a lot of elbow grease
    Thanks!
    Oct 2013
    Na google ako sa elbow grease [emoji16]
    but don't use wire brush, unless you intend to re-paint it afterward.
    Jan 2009
    Correct me if I'm wrong.... the wrap seems to have made the paint brittle and the pieces that are coming off are actually the paint clinging on to the wrap.
    A 2000-Watt heat gun should be able to remove that.
    Oct 2013
    Thanks sa inputs mga paps
Car sticker (I made a mistake [emoji51])
