Results 1 to 20 of 45
    Oct 2011
    can i use nanosliq everyday? hindi ba masisira ang paint? i know wax hindi pede, kaya di pedeng gamitin nanoglos araw araw....
    Thanks for the reply
    Oct 2008
    if you mean nanosliq will decrease paint thickness, then no.
    more contact = more chance to make swirlmarks. making sure everything is clean, your tools, the car, will minimize the damage
    the cleaner the car, the easier it is to wash
    Oct 2011
    I don't think that using NanoGloss or Sliq will harm or thins your car paint.
    Oct 2011
    hmm, nanogloss is a wax. from what i read, wax can damage car paint if you use it everyday. dapat ata once a month lang. i want to use nanosliq kasi. specially pag umulan. may mga water marks sa kotse, using nanosliq, nawawala sya.
    Oct 2011
    Quote Originally Posted by sarimanokftw View Post
    Yes, pwede NanoSliq. Quick Detailer kasi un. It gives shine to your car but doesn't protect your car paint. Maybe you could apply NanoGloss on a weekly basis.
    Oct 2011
    ahh ganun ba? kala ko sacrificial layer ang nanosliq. protective layer sya ng kotse. hmm
    Mar 2018
    NAno sliq ,
    I only use this one, every time I put a new layer of nano gloss, every 4 or 6 weeks.
    DRY WASH aslo from MT
    I use this for maintenance , every after car wash.
    Wax cleaner
    As the name states it strips light contaminants and some wax residue
    I use this for paint prep.
    Yes po safe ang nano sliq but for maintenance I rather use dry wash.
    Sent from my ASUS_X00DDA using Tapatalk
    Sep 2006
    I've read somewhere in this forum that you could dilute nanosliq with water to avoid streaks.
    Oct 2018
    Quote Originally Posted by jhnkvn View Post
    1. Wax doesn't harm the paint per se. Rather it's the contact.. less contact = better. That's why durability plays a huge role in the purchase of wax products. There's no use in layering Nanoglos over a day old Nanoglos practicality-wise. It's like putting lotion on yourself once.. and then another layer of lotion again.
    3. Nanosliq is considered a spray-on wax rather than a cleaner QD. Or as Doc said, it's a booster wax. So it forms a protective layer above the wax and also gives it a slick feeling and that shine we all love. You can say it's somewhat a sacrificial layer since it suffers in terms of durability. One wash or 2 rainy days would be its durability.
    3. I wouldn't recommend spraying Nanosliq on a heavily soiled car. However, minor dust and dirt accumulations are fine.
    4. Nanosliq needs buffing. It's not like OCW where you can simply spray it and then let it dry. Hence I would recommend application on a dry surface. But applying it pre-drying should be okay too since my Nanosliq is diluted 50% with distilled water You need to ask the other gurus like Umi to clarify this.
    *sarimanok
    Might be more practical to dilute the Nanosliq with some parts water. However, you should really try ONR ;)
    *sean-archer do you use NanoSliq din? I used kagabi yung small bottle, ubos for my sedan! pero cleaned all panels. Di ko lang alam if pwede din siya sa glass and lights.
    Will dilute this din para medyo ma cover lahat ng parts ng car. medyo natipid na lower panels kasi sobrang konti nalang ng natira.
    Oct 2003
    If you could try the other branded products, mas magiging okay ung experience nyo. Believe me.
    Quote Originally Posted by zechs View Post
    medyo na hatak sa "nano" ��
    dapat grumaduate na sa nanosliq ��
    Feb 2019
    Aside from NanoSliq, Microtex now has Quick Shine and After Wash in their line-up are they all the same?
    Jun 2011
    NanoSliq ang huling coat.
    Pure silicone lubricant main component.
    Main purpose para dumulas at hindi kakapit ang dumi, alikabok, o putik.
    Since concentrated silicone lubricant siya, kaya nag streaks. Ingatan hindi mahawaan ang windshield o wipers, mag streaks at chatter ito.
    May na discover ako mas ok na gamit ng NanoSliq silicone lubricant, concentrate sa basahan at punasan sa door seals at hood weatherstrip. Pang protection sa pagtuyo sa araw, at pag dikit sa metal at langitngit.
    Since water based na Silicone, mukhang hindi harmful sa rubber seals, hindi tulad ng spray based Silicone protectant na may harmful propelants at mahal pa.
    Feb 2019
    Quote Originally Posted by bxr monkey View Post
    Okay thank you for the heads-up. Right now I bought Quick Shine by Mirotex and I just get confused with this products that looks similar in function.
    I like the nano slick kasi pansin ko lang madali sya mag wear off compared sa regular wax lalo na kun panay ulan o carwash.
    Sep 2006
    I don't have any basis but I use nanosliq QD once a week, then spray wax the next week. Nanosliq again for the 3rd week and so on.
everyday use of NanoSliq
