Results 31 to 32 of 32
February 5th, 2003 10:55 AM #31
One question about the colorsanding process...
How many times should you rub the sandpaper across a particular area? For a two by two section of the hood, how many times would you glide the sandpaper on that particular section?
richi: I saw it na. Thanks for the info.
February 6th, 2003 02:25 PM #32
you can't really describe that, coz each situation is different, it all depeneds on how your painted area is as you sand...
high idle RPM at engine start
