Ang weird, i hand-applied this product to a scratch located on my right fender. after mawala yung scratch, i topped it off with a 100% carnuba na turtle wax. the surface looked nice and new again
But after a few days, i was in a parking lot sa mall na may indoor lighting, i saw circle traces of 3M Scratch Remover and parts of the scratch that i left out...
1. Bakit ganon? mali ba yung pag-apply ko ng SR? i followed the instructions written at the back of the bottle naman... Tips naman diyan... thanks! =)
2. Ano po yung iba pang mas maganda na SR that needs konting rubbing lang? for fine scratches lang naman... thanks! gusto ko na palitan eh! i tried turtle wax swirl and scratch remover, pero swirl lang nawala, nandun parin yung mga fine scratches...
3. Hesitant ako to use any rubbing compund kasi bago palang yung car, but i saw this product "turtle wax polishing compund and scratch remover" ok ba siya?
if possible, get scratchX..(pero, IMO halos kaparehas na lang nito ang 3M mo eh) and whatever method you use, as long as hand-applied, expect some elbow grease. hehehe.. though machines may work better, they don't get to attack the minor scratches the way our hands do. isolated kasi...
and also, avoid using rubbing compound kung hindi ka talaga sigurado about using it. (sabi nga sa Meguiar's: try to use the least abrasive product...or something to that effect...)
anyway, here's my thoughts:
1) minsan, akala mo natanggal mo na ung scratch and residue of the material used in removing it. if possible, try to inspect it in different lighting conditions. (Fluorescent light reveals swirls very very well...)
2) after removing, use soapy water / QD to remove any remaining residue. yup... be sure to re-wax the affected part..
3) or... natanggal na wax mo (which hid the scratches and swirls in the first place) then after a few days ayun...lumabas na uli.
4) minsan you have to do a few passes to remove some scratches.
Hey there
From my experience, 3m is a little too aggressive. I tried it once and it hazed, katulad nung sinabi mo. You have to break it down properly, continue rubbing it hangang mag-thin out yung liquid or paminsan magddust, if not try using a lighter polish. ScratchX is good, ok din ang Mother's.
Turtle wax has fillers in it, kaya after a while lumalabas yung scratches.
