Results 31 to 34 of 34
December 22nd, 2007 12:30 PM #31
magastos ang polymer (Plastic) you need expensive die molds and injection machine kaya malalaking company lang my kayang gumawa nyan..sa die mold pa lang dami ng problema cavity shrinkage,flashing at leak
- Jan 2008
- 66
March 31st, 2008 03:16 PM #32Ebooks for Added Knowhow
Rotational Molding Technology
http://**********.com/files/4972014/1884207855.rar.html
Repair of Vehicle Bodies
http://loadingvault.com/search.php?q=vehicle+repair
Materials for Automobile Bodies
http://**********.com/files/94132027...ile_Bodies.rar
http://w13.easy-share.com/1699610074.html
http://************.com/files/3609271http://www.filefactory.com/file/e2a9bb/
Automotive Steel Design Manual
http://**********.com/files/98366829/Automotive_Steel_Design_Manual.pdf
Tsikot Member Rank 4
- Jan 2003
- 1,403
June 8th, 2008 04:01 PM #33
October 8th, 2009 12:37 PM #34
*safeorigin should read this!
[SIZE=3]Small Leyte town assembles bamboo car[/SIZE]
By Vicente Labro
Philippine Daily Inquirer
First Posted 01:34:00 09/06/2009
Filed Under: Environmental Issues, Road Transport
TABONTABON, LEYTE, Philippines—Move over electric cars, bamboo cars are the next eco-friendly transport.
A farming town has started to assemble cars using bamboo and other indigenous materials in pursuit of the green agenda. It has also fabricated equipment for waste recycling.
Tabontabon, a fifth-class municipality of over 10,000 people and situated 30 kilometers south of Tacloban City, began the environment-friendly projects on the initiative of its mayor, Dr. Rustico Balderian.
Balderian, 53, a physician serving his first term as mayor, recalls that the car assembly venture arose from the town’s need for an alternative means of transportation.
Jeepneys seldom ply the route because it takes hours for the vehicles to fill up with passengers. The main mode of transport is the motorcycle, locally known as habal-habal which, according to the mayor, is prone to accidents.
To solve the problem, Balderian says he looked around for a form of transport that can compete with the habal-habal, jeepney and multicab in terms of cost and efficiency. With the help of residents and out-of-school youths, he experimented with a three-wheeler and a car with a one-cylinder engine.
[SIZE=3]Three car models
[/SIZE]
They finally settled on a two-cylinder engine that runs on coconut-based biofuel with the body made of indigenous material.
Their efforts resulted in three prototypes of the eco-friendly cars assembled under the Tabontabon Organic Transportation Industry (Toti) livelihood project.
The Eco 1 model car, designed by Balderian, is made of indigenous materials, except for the engine, tires, chassis and flooring. It can seat 20 people, including driver, and can run on one gallon of biodiesel for eight hours.
It can climb a 20-percent incline. Its body, including the roof, is covered with woven mats. It has a steel plate flooring.
The Eco 2 model car is 70 per cent made of bamboo, including body and flooring. It can seat six passengers and has a stereo system. It can run on one gallon of biodiesel for eight hours and can climb a 20-percent incline.
The Eco 3 model car is an improved version of Eco 2. Bamboo makes up 90 percent of the car, including chassis. It can accommodate six passengers.
The three car models have been driven around town and even participated in a parade in Tacloban City.
Stronger than steel
Balderian says the use of locally available bamboo, whose tensile strength is greater than steel, lowers production cost. Bamboo is also pliant and light.
“Bamboo cars are environment-friendly and could help mitigate the adverse effects of climate changes,” he says.
According to the mayor, it takes around five tons of ore to produce a ton of steel plate and to transform the ore into steel plate, some five million Btu of heat is needed.
Balderian claims the[SIZE=3] car body can last 10 years as the bamboo and indigenous materials will be laminated or treated with polyurethane to withstand the heat and rain.[/SIZE]
There is also no danger of the vehicle catching fire as polyurethane is fire-resistant, he adds.
Mass production
Balderian estimates that the Eco 1 car will cost about P200,000. Since it runs on coconut biofuel, it will not be dependent on the more expensive fossil-fuel.
Some of his fellow mayors, he says, have already signified their interest to buy these environment-friendly cars.
Balderian says their group is seeking a classification for these “eco-vehicles” from the Land Transportation Office.
So far, they have only produced three prototypes and will only assemble additional units if there are orders.
If there is enough interest, they plan to mass-produce the cars.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
