Results 1 to 16 of 16
    Dec 2004
    Whenever my A/C is turned on, patches of fog or mist appears on the same spot of my windshield - middle bottom area. Lumalaki ng lumalaki hanggang mahirap na visibility. Sa labas yung fog. I use my wiper to clear it off pero bumabalik. It's not even very cold inside the car. Tama lang. The only way to quickly get rid of it is to turn off the A/C and roll down the windows. This can happen no matter what the temp is outside. May nakaexperience na ba ng ganito? How do you fix this?
    Apr 2014
    Masyadong malamig sa loob nang car compared to the outside temp. try putting your ac to low.
    Dec 2004
    Actually, hindi pa masyadong malamig inside. The AC is not set too high. If I turn it down, maiinit na. Other cars na masmalamig pa on the same day, wala namang ganun.
    Posted via Tsikot Mobile App
    Jun 2013
    try to change the air flow, merong selection doon sa tabi ng switch ng aircon pero diko alam yung tamang tawag :D
    Jul 2011
    baka may rain x or similar product ang windshield mo. pa detail/cleaning mo na lang sabihin mo problema mo kung kaya nila.
    Sep 2005
    try opening your window for a few seconds..
    lumang kotse na ba? baka hinde na lapat yun vent kaya meron lumulusot na air papunang defogger...
    Sep 2005
    san ba location mo? usually nangyayari yan pag mas malamig ang temperature sa labas kesa sa loob nang car..
    na experience ko yan sa Baguio and Tagaytay.. dito sa Metro Manila pag malakas ang ulan sa gabi.. pero pag normal day at may araw pa.. hindi dapat mag fog yan..
    ano ba sasakyan mo sir? mali lang ang vent nyan tignan mo lang sa may harap mo kung tama dapat sa muka nakaharap ung arrow... kung tama naman sira na yan foam nyan.. kaya ganyan yan kasi sumisingaw ang hangin... try mo lang takpan ng foam..
    nangyari na din sa akin yan to the point na huminto ako kasi hindi ko sya ma-control(either lakas ko aircon or hinaan) and wala na akong makita sa windshield, i tried setting the AC to low cool and fan tsaka hi cool, wala din, binuksan ko na lang bintana ko, siguro mga twice or thrice nangyari pero lately hindi ko pa sya nararanasan ulit
    Sep 2012
    Try putting your hand sa area na yun tapos pakiramdaman mo kung may lumalabas na hangin sa vent na malapit sa area nya.
    Kung meron nga lumalabas at lumang sasakyan yan na may vent selector high chance na hindi lang nag close properly pag nag adjust ka ng switch kaya gagalaw galawin mo lang hanggang mawala. Kapag ayaw pa rin mawala pwede mo na ipa sched ng baklas dashboard para hanapin
    Dec 2004
    Thank you sa mga replies. Sa manila lang ako and it's an '01 rav. Im actually selling it pero gusto ko pagawa muna mga maliliit na things na ganun for better customer satisfaction. It's probably the vent nga. Dapat ba aircon specialist ang gagawa ng ganon?
    Jan 2003
    ^Most likely an aircon shop. Depending sa design, pero for sure you'll need to remove parts of the dash or the whole dashboard to access the vents. Pwedeng sira yung cable, or yung vent motor or worse, foam insulator.
    Oct 2009
    mas mataas ung cold temperature kaysa sa air vent..
    ilagay sa low ung thermo..baka naka sagad..timplahin mo ng tama lang..
    kung naka high ung thermo matagal mamatay ung compressor.diretso ang lamig.pero naka low naman ung blower mo.
    tendency ,hindi maka circulate ung hangin at lamig sa loob ng car mo..kaya kumakapit siya kung saan
    malapit ,na madaling mag absorb ng lamig wind shield,,
    ilagay mo number 2 ung fan at bawasan ung thermo..
    Jul 2010
    Sir, try nyo muna i set sa icon na may arrow papuntang mukha (see yellow highlight) baka napunta kayo sa deffogger (see green highlight). Kasi may mga vent malapit sa windshield which is for the defogger. baka kasi yun yung cause. gaya nga ng sabi mo nag s-start sa baba (most likely from the defogger vent) tapos hindi naman malamig ang hangin sabi mo (kasi nga baka nakadefogger).
    Dec 2004
    Actually, nakaset na siya dun sa 1st icon. Di ko binabago ever since. I think sa vents yung problem as what others assumed. At least I know na what to look for first.
Windshield fogging
