Results 1 to 20 of 20
    Hi peeps!
    I'm new here and I'm hoping that you guys can help me about my car problem. Here's the situation:
    I have a 7G (mitsubishi), Lately it was emitting WHITE SMOKE (even on idle), loosing Oil and the temp would rise sa traffic. I checked the radiator and the reservoir and found out na may oil sa loob..
    My questions are:
    1. May connection ba ung White Smoke - Loosing Oil - Rising Temp?
    2. What does white smoke mean?
    3. Kailangan ba ng Top OH, if yes how much kaya yung magagastos?
    Thanks for those who will reply!
    Optiplex
    Aug 2006
    bro, base lang sa mga nabasa ko na...
    white smoke: cylinder head gasket mo, may singaw..pumapasok ang tubig sa makina..(tama ba ako?)
    overheating: obviously, pag may singaw ang head gasket, mauubos ang tubig mo so kukulangin talaga ang tubig sa radiator which causes the temp gauge para tumaas...
    loosing oil: baka valve seals or piston ring...
    kung makakaya ng top OH, pwede...mas makakatipid ka...pero wait pa natin mga gurus dyan...
    top OH: labor siguro mga 2.5-3k..except mga gaskets and seals...
    Quote Originally Posted by buraot View Post
    Thanks sa reply!
    Suspect ko sa nawawalang oil is that napupunta sa radiator.. Pag check ko ng radiator, maraming oil yung cover...
    Can Top OH do the trick?
    Aug 2006
    98% of the times it's the headgasket... oil goes to the radiator, then to the reservoir... How many miles/km's on your car? Do you beat on your car a lot? Make sure to mainatain your Mistu properly and timely, and always keep an eye on such... You have probably overheated a few times before, which is the most common reason of headgasket issues... GL
    Joven
    Quote Originally Posted by blink21me View Post
    Joven
    100K plus mileage. Nag overheat na ako nun and kakapalit nung headgasket mga 3 mos ago... usually tumataas ang temp pag traffic and may oil yung radiator cover..
    Aug 2006
    Quote Originally Posted by optiplex View Post
    nag overheat ka na pala...at napalitan na ang head gasket...? dapat ndi na sisingaw yan..have you checked your cylinder head? baka nag-warped at dapat ire-surface?
White Smoke, Overheating and Loosing Oil
