Results 1 to 20 of 29
    Feb 2013
    When i have gone to angeles pampanga and capas tarlac my van is in normal temperature but when we are along nlex going back to manila i see the temp in the dashboard that the temp is not going down since im in a fast drive it usually going down but the temp is below the middle or in above cold it stays for long, so i stop by to shell gas station along nlex when i put water in the radiator it lose around 2 liters of water and to rusty. When i gone to work last friday i just experience the same problem but the temp go down, so on the next day i check again the radiator so it comes up that it lose 1.5 liters of water again, the problem is it has no leaks the hose has no leaks also. When i go to work today i dont experience the problem because theirs no traffic in EDSA. So what do you think the problem tsikoteers? Thankyou so much!
    May 2004
    it seems you don't have thermostat valve installed..
    Feb 2013
    Sir how to check thermostat valve?
    Jan 2009
    Quote Originally Posted by 1997 View Post
    A missing thermostat valve will never cause an engine to overheat. If anything, it will be the opposite.
    Jan 2008
    malamang nag overflow yan sa reserve tank kaya nagbawas ng tubig... possible gasket problem or overheating due to dirty radiator
    Jan 2004
    agree with sir yapoy86
    could also be a warped cylinder head
    Dec 2009
    according to your statements rusty yung radiator...
    i suggest ipalinis mo radiator mo sir have it cleaned inside out... then gumamit ka coolant at distilled water.. 60% water / 40% coolant....
    isabay mo na din sir ang pag check sa mga hoses mo if meh leak at malutong na..
    plus check the thermostat if you have one kung nag fu-full open lift, baka na stuck na yan sa dami kalawang
    napapansin at bigyan attention lang cooling system once na cause na ng sakit ng ulo....
    Feb 2009
    i will have to disagree with this. you probably haven't worked on cooling systems long enough. some thermostats are three way and if you remove the thermostat, the coolant only circulates in the engine block and most often does not get to the radiator. the radiator might seem normal but the engine will have fever.
    Jan 2009
    I tip my hat to you sir. :D
    Though, statistically, it's quite unlikely that the OP's car has a three-way thermostat. But I didn't see any car make or model in the thread so I can't be sure.
    Dec 2009
    me too.. personally, on passenger vehicles ata, or the common car, parang wala pa ako nakita na three way thermostat... though baka meh ibang models na factory equipped nito IMHO....
    err... what make is your van?
    check the overflow cannister.. if it's likewise empty, then you're overheating. if it's full, your leak may be in the engine, or somewhere well-hidden in your radiator, or your water pump..
    check also the radiator cap.. baka sira na ang rubber lip..
Radiator problem!
