Page 1 of 2 12 LastLast
Results 1 to 10 of 31
    Jul 2005
    My ride is a Nissan and my aircon setting is at 25 degress celcius. I find this setting to be the most comfortable. Not too cold and not too warm. Kaya lang whenever i take my car for PMS, pagkuha ko the aircon is down to 18 degrees celcius, which is just freezing for my taste. I'm just curious why the guys at the casa always put it in this setting. What's the benefit in setting the aircon at higher or lower temperature setting?
    Kayo, ano po setting ng aircon nyo?
    probably they also test the cooling capacity of your a/c by setting it at higher temp. but hindi nga maganda to leave it that way if your preferred thermostat is only at 25 degrees
    mine is not digital, a simple slide switch which I normally set at 30-50% lang.
    i dont know exactly the temperature readings pero i just set my thermostat at around 1-2pm.
    Quote Originally Posted by 1D4LV View Post
    vlad, more than 50% malamig na rin yan. kahit tanghali. have you tried at 10 o'clock at least?
    Aug 2005
    Sa Avanza, Fan at 2, Thermostat at first click from off.
    Sa ZZ, Fan at 1 or 2, Thermostat at minimum.
    May 2008
    Sir Meledson, mas matipid ba pag ganyan setting sa avanza?
    Yun kapatid ko kc pag gumagamit yung Fan sa 1 lang then yung thermostat pagkataas taas...
    Kala namin kc mas matipid pag fan at 1 eh...
    hehehe. malamig nga.... pero pawisin ako eh. hehehe. the least i had it set is at 11-12 o'clock.
    Jun 2008
    depends on the weather: raining days and christmas time 7am . summer 12o clock. tanghaling tapat naka bilad sa araw summer; 2 o clock. mornings papasok sa work 9 o clock lang. pag maraming sakay 12 o clock.
    vios 2009. 1.3
    Sep 2005
    pag pinasok kasi sa CASA.. dyan natutulog yung mga tech pag lunch break.. kaya todo aircon..
    Aug 2008
    For me, rule of thumb is: unnecessary use of aircon equals waste of fuel. A 25deg setting means the aircon works less often than the 18deg setting. Note also, everytime the aircon compressor works means more load on the engine, which means reduction on the life effeciency of your engine. Think about it. Choice is yours.
What's your aircon temperature setting?
