Results 1 to 7 of 7
July 14th, 2011 02:21 PM #1
guys, hanggang saan point ba sa temp gause ang overheat? kahit ba over lang ng konti sa middle point overheat na yun? 3/4? or dun sa red line? hope somebody can clarify,tia!
July 14th, 2011 02:47 PM #2
if its above normal level, meaning its running hotter than usual. pag 3/4 na, malapit na mag overheat yan. pag red na. overheat na.
- Sep 2008
- 630
July 14th, 2011 05:30 PM #3kung nasa red line na, means start na ng overheat. in between that line and the normal line indicator na yan na meron problema. cheers
July 15th, 2011 12:30 PM #4
Basically, that's it. It's not "overheating" per se until it's at the red line. But if it goes even slightly above normal, the best thing to do is pull over and check for reasons for it being above normal... low coolant, stuck fans, etcetera... because ignoring abnormal temperature variations, no matter how small, can lead to disaster in the future.
- Apr 2009
- 1,902
July 21st, 2011 08:53 AM #5Matanong ko lang mga sir!
I was stupid enough to ignore the disconnected water pump gauge for three days now (I was too lazy to reconnect it since I can't touch it when the engine's hot).
This morning, while I was parking the car in the office, steam suddenly (and persistently) fumed out of the hood. After I parked the car, I saw a considerably short trail of water from where I did the maneuver and I was right, when I popped the hood, that it came from the radiator reserve tank.
Found out my radiator fan got stuck up again. After a few attempts, I managed to desperately do its electricals. But I'm sure it won't work again this afternoon, so I might as well leave the car there.
Pardon the novel and here's the question:
Would that [obviously, the overheating due to the coolant reaching intolerable boiling point and steaming out] do my engine internals any harm?
This is the first time it happened, but the engine already clocked 200,500 kms on the odometer.
Any other headache to expect aside from the cylinder hear gasket replacement?
Thanks.
July 22nd, 2011 09:26 AM #6
To Isa 1023
Usually if your engine reaches overheat or almost the rubber oil seals, hoses, belts etc... tend to brittle.
Sa Exsior ko nag almost red line but prevented but after a few months the oil seals started leaking along with the valve cover gasket.
I ended up replacing the following of precautionary measures and to prevent more expensive repairs
Crankshaft oil seal
valve cover gasket
camshaft oil seal
various hoses
belts
and many more some should change cylnder head gasket but that is if you severely overheat na. Have your mechanic check it thoroughly.
- Apr 2009
- 1,902
Monk-owned R53
