Mga sir question lang, what if may tumatagas na tubig sa hose sa bandang likod ng makina (passenger side?) Ano kayang problem nun? And pwede kayang tapalan ng sealant yun? Nagooverheat kasi yung makina, feeling ko galing radiator yung tubig dun (nauubos kasi tubig sa radiator which causes to overheat) tama po ba?
Yung oto ko po is Honda City EXI 98, AT. Thank you
if you are sure that the hose is the culprit, then have it repaired.
mahirap mag overheat sa daan. don't scrimp on it.
and while you are at it, pa flush and pa linis mo na din yung radiator mo, have your aux fan checked, also have your water pump checked.....
I had my entire hose replaced na mga sir sa trusted mechanic, so far so good naman. Sana wala ng tagas. Next time papalinis ko naman yung radiator and makina. Thanks alot!
