Results 1 to 6 of 6
- Nov 2014
- 2
November 14th, 2014 11:37 AM #1Mga sir question lang, what if may tumatagas na tubig sa hose sa bandang likod ng makina (passenger side?) Ano kayang problem nun? And pwede kayang tapalan ng sealant yun? Nagooverheat kasi yung makina, feeling ko galing radiator yung tubig dun (nauubos kasi tubig sa radiator which causes to overheat) tama po ba?
Yung oto ko po is Honda City EXI 98, AT. Thank you
November 14th, 2014 12:43 PM #2
Replace the hose its cheaper than overhaul if you leave it that way. May replacement naman yan
November 14th, 2014 03:31 PM #3
if you are sure that the hose is the culprit, then have it repaired.
mahirap mag overheat sa daan. don't scrimp on it.
and while you are at it, pa flush and pa linis mo na din yung radiator mo, have your aux fan checked, also have your water pump checked.....
- 52,509
November 14th, 2014 04:07 PM #4i recommend replacement of the entire length of hose. repairs do not last long..
my experience..
November 14th, 2014 05:22 PM #5
Replace the whole hose. hindi kaya ng sealant yung ganyan case. it will eventually leak pa rin.
- Nov 2014
- 2
November 15th, 2014 10:59 AM #6I had my entire hose replaced na mga sir sa trusted mechanic, so far so good naman. Sana wala ng tagas. Next time papalinis ko naman yung radiator and makina. Thanks alot!
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
