Results 1 to 5 of 5
    Jan 2017
    How long does it take before the water leaking under the car stops? Used the car for 1hr, naka 3 yung blower tapos yung aircon is 1/3 nung knob yung pagkaikot. Almost 1 hour na pero may natulo pa din pero konti nalang. Sure ako na tubig kasi nilagyan ko ng tabo para masalo yung tulo tapos clear, walang amoy at tubig nga lang talaga. Thanks!
    Jul 2013
    It will only stop if you stop using the aircon.
    it is condensation from the ac system. it is nornal.
    Quote Originally Posted by Vash93 View Post
    i do not know how long after the car is parked, before that dripping stops.
    but as stock says, it is normal, po.
    i wouldn't worry.
    Dec 2009
    ^that is condensation from low temp to high temp as the low temp is no longer maintained because you just turned off the engine
    After all air con operation depends on the engine
    Its smilar to a glass of water with ice left on the table
    Sent from my GT-P3110 using Tsikot Forums mobile app
Water leak from aircon
