Results 1 to 10 of 13
Toyota is my choice
- Aug 2005
- 2,063
November 11th, 2005 02:52 PM #1When your driving your car and when the aircon automatic A/c switch to on you can hear vibrating sound whenver you press the gas pedal more the vibrating sound you are feeling.
something wrong or a maintenance would be replace with my aircon parts? my aircon still works good and very cool..
its just the vibration that bothers me..
pls help.. Car is corolla Xe 96 carb
thanx..Last edited by finchy18; November 12th, 2005 at 01:45 AM.
November 11th, 2005 03:08 PM #2
bai -- i dont know if this is relevant to your query but here goes. i used to drive a box type corona (yep the 90s macho machine model but it was 4 door model lang) and it had a bad bad vibration problem that always happens whenever the aircon was turned on. there was no problem with the aircon though as it was still cold
it turned out that kulang sa support or dampeners ang area around the compressor. i never got to fix it though and just sold the car
basig mao ni ang problema nimo?
Toyota is my choice
- Aug 2005
- 2,063
November 11th, 2005 03:16 PM #3bai IDOL tka.. salamat talaga.. parang nga kulang ng support ang compressor ko.. pero i need more comments bro.
thanx ha sa fast reply..
Toyota is my choice
- Aug 2005
- 2,063
November 11th, 2005 09:26 PM #5yong nasa labas ng timing belt? diba dalawa yung makikita mo sa belts aside from the timing belt.. baka loose na nga kasi matagal na to eh di pa na replace....
Toyota is my choice
- Aug 2005
- 2,063
November 11th, 2005 09:53 PM #7which belt bro? where exactly? magkano ba ang belt? madali lng ba to mag pa replace?
November 11th, 2005 10:05 PM #8
yun belt sa compressor which extends to a idler pulley then into the the engine pulley. Basta check mo kung maluwag. Bumababa ba ang RPM mo pag on ang ac?
Toyota is my choice
- Aug 2005
- 2,063
November 11th, 2005 10:11 PM #9hindi nman bumaba.. normal nman.. ma ingay lng pero hinda masayado.. sometimes lng maingay kpag full a/c ako.. pag automatic a/c sya tumotunog..
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
