Results 21 to 30 of 40
September 10th, 2012 01:32 PM #21
If water was never used during the vehicle's life then I don't think you'll have the kalawang problem in the first place. Coolants also prevent rust and scaling. Water means more income for the radiator repair guys ;) There are radiator flushing solutions that can be used to flush out the rust. They're good for just a few kilometers though.
When the engine overheats and the rad cap cannot vent enough pressure the plastic radiator ends will blow first. Replacing the plastic with tanso will make the rad stronger but guess what will blow when the engine overheats again? The head gasketLast edited by JohnM; September 10th, 2012 at 01:34 PM.
September 10th, 2012 01:34 PM #22
Headers, tanks, IMHO its the same. We are referring to the things crimped on both ends/sides of a radiator core. Thank you for enlightening us that it is just for "cost reduction" purposes.
Re: distilled water, yes I suggest you use that, and the proper mixture/ratio of coolant if you want. I use distilled water in all my cars, no problems whatsoever.
- Aug 2005
- 553
September 10th, 2012 03:12 PM #23Much obliged, Sir.
Distilled or otherwise doesn't matter. Clean and filtered is all you need. Once a hypotonic solution comes into contact with any and all metal parts it becomes contaminated and will dissolve anything it can anyway.
I suggest mixing your coolant/water outside the radiator before pouring it into your loop this minimizes your water from dissolving anything else.
- 54,289
September 10th, 2012 10:58 PM #24only if your engine and radiator are made of glass.
alas, our engines and radiators are metal alloys. they corrode over time and heat. the corrosion product is the dumi or kalawang that they refer to.
it is the duty of the coolant additives to slow down or prevent metal corrosion..
will these coolant chemicals solidify these kalawangs into more solid pieces? i don't know..
you know, we never had this problem in our cars for the 20 or so years we had them (air-cooled volkswagens.. heh heh..)Last edited by dr. d; September 10th, 2012 at 11:06 PM.
September 11th, 2012 08:15 AM #25
September 11th, 2012 11:49 AM #26
- Aug 2005
- 553
September 11th, 2012 01:38 PM #27^lol double reminders then. :D
But people, you have to stop trusting the science that the corner "RADIATOR COVERTION", "OVERHOLE" establishments provide. There is no science!
If you remove the coolant you will have more rust. The fact that it will clog more is because they really never cleaned it properly.
Scaling will attract more scaling. Once your solution (coolant) is saturated, it will begin depositing more particles on the encrusted surfaces causing more clogging.
Sus ginoo!
- Aug 2005
- 553
September 11th, 2012 01:40 PM #28
- 96
September 12th, 2012 11:18 AM #29Wew! dami na pala answers dito.. salamat mga sirs..
HAd the radiator cleaned last weekend. tested it for a long drive. kumukulo pa rin (pero take note di pa rin tumataas ..kalahati pa rin ng gauge)
Again, the engine runs great and I dont see any pagbabago sa hatak, maayos pa rim, kahit tirik ang araw..
What test na pwede ko magawa para malaman ano sakit? water pump kaya....?
help again sir... thanks alot,,,
September 12th, 2012 11:20 AM #30
They replaced it with flashing green light prior to turning yellow. I guess it simplifies things?...
SC (temporarily) stops NCAP
