i dont know exactly the correct normal temp reading of diesel engines but based on your readings in gas engines that seems to be normal,i think but not sure youll be fine because the only time to replace thermostat is when it gets bad like stuck open,stuck close or weak spring and the only way to check it,is to take it out and test it.
