Results 1 to 10 of 16
- Apr 2008
- 94
September 19th, 2009 11:47 PM #1Guys, need your help, I have a 2007 Ford Everest 3.0 4x4 AT.. I started noticing my temp gauge going up a couple of months ago, but only when I drive aggressively.. On normal drives, city traffic(stop and go), and on provincial roads.. Normal naman siya, pero sa uphills which requires more RPM(around 2500), tumataas nanaman siya, pero pag binabaan mo RPM say about 2000 rpm, bumabalik siya sa normal.. I checked my coolant levels and their all normal.. Wala naman leaks, lagi din full sa radiator, ok din yung coolant reservoir ko.. I tested if my radiator is clogged by opening the radiator cap, turned the engine on then rev it, it goes up and down naman, medyo nagooverflow lang when you rev it but as soon as you release the pedal, the water goes down again.. My AC is ok naman, malamig naman siya..
Any suggestions? Anyone know a shop who's an expert on these kind of things somewhere in Banawe QC area? Takot ako sa mga freelancers eh..
September 20th, 2009 02:37 AM #3
try mu din thermo reader sir, may not reading accurate measurement.
or yung auxiliary fan ba yun?
magkaka konekta yan eh. if the thermo gauge does not read accurate temps, the fan will not start. or if the fan is not working, the gauge is reading faulty measurements.
pacheck mu na lang sa casa sir, baka cover pa ng warranty yan
September 20th, 2009 04:44 AM #4
Check mo rin iyong temperature gauge baka hindi na accurate ang reading . Siguro kung hindi naman nag ooverheat ayos lang siguro iyan .Check mo rin auxillary fan mo kung gumagana.Minsan gumagana pero mahina na ikot nito dahil sa motor nito.
- Apr 2008
- 94
September 20th, 2009 10:46 PM #5
- Apr 2008
- 94
September 20th, 2009 10:48 PM #6
- Apr 2008
- 94
September 20th, 2009 10:50 PM #7Well so far hindi pa naman nag ooverheat, kasi pag nakita ko ng tumataas yung temp gauge, lay low na agad ako sa driving.. Weird lang kasi at normal roads hindi naman siya tumataas, even sa city traffic(stop and go) hindi din naman tumataas.. Pag uphill or aggressive driving lang talaga..
September 21st, 2009 01:47 AM #8
Sir ganyan yong LC100 series namin dito sa company. Nagpalit lang kami ng clutch fan. Try niyong umaandar yong engine niyo na nakaIdle lang. tapos pakiramdaman niyo sa kamay ang hangin pahigop (pabuga) papunta sa makina. Tapos paapakan niyo ang accelarator pedal hangang 1500RPM kung gaano kalakas yong buga ng hangin. kapag kunti pinagbago, talagang Clutch fan na ang deperensiya.
- Apr 2008
- 94
September 21st, 2009 06:36 AM #9Thanks sir, if ever, mukhang sira na agad yung clutch fan ko, original pa naman din yun.. Siguro wala pang 8 months nung nagpalit ako..
September 26th, 2009 02:43 AM #10
Sir Musta na yong Everest niyo. OK na ba? Pag di OK Subukan niyong pumunta first week ng October sa Shop na ito? Hanapin niyo na lang si Fermin.
Fermin Auto Aircon Electrical and Radiator Repair Shop
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
