Results 21 to 24 of 24
October 1st, 2006 07:02 AM #21
Hindi man lang umabot ng isang araw. Something was wrong. Ibalik mo sa shop. May warranty sigurado yan. Kaya lang ang walang warranty ay ang perwisyo.
October 1st, 2006 07:06 AM #22
hopefully overcharge lang sana ang dahilan otherwise maaring maulit uli ang problem. most ac tech kasi tamad magcheck ng high side while re-charging the system un lang low side ang minomonitor nila, unlike kung medyo bigatin un shop na ang gamit ay recovery and re-cycling machine nasusukat nila ang tamang refrigerant quantity and namominitor both the high and low side
October 1st, 2006 02:11 PM #23
inayos na mismo ng uncle ko
pinalitan nya ng hose since sobra daw yung 350 psi
madumi yung condenser ko kaya daw uminit yung hose ayun dahilan kaya sumabog.
so far ok na yun, pero magpapalit na rin kami ng radiator since
me nakita na kami crack sa harap nya, dun tumutulo ung coolant.
- Oct 2006
- 43
October 1st, 2006 11:11 PM #24monitor mo na rin yung hi-side pressure mo.. ok kung around 200 psi lang.
tingin ko problema nyan e either clogged na yung condenser (mejo mahal yung replacement) o baka nag-hinang ng hindi maganda si mr tesda sa inlet ng condenser na naka apekto sa flow ng refrigerant which led to pressure build-up on the compressor's discharge.
