Results 11 to 18 of 18
January 26th, 2024 05:47 PM #11
My 2013 civic humina ang lamig ng 2017, sabi ng denso after using their analyzer, add freon, 250 kesos only, ayos naman till 2023, humina ulit lamig, pina check up ko sa maliit na shop dito sa amin, reco cleaning, quotation almost 10k. Sinubukan ko pakarga freon sa isa pang shop, 500 kesos, 7 months since mas malamig pa kesa Territory ko.
January 26th, 2024 05:52 PM #12
agree din ako. kung lumalamig naman at walang amoy, palit o linis filter lang kung mga washable type...
an AC shop will always insist na kailangan i cleaning, then palit yung evap valve yata yun, then top up ng refrigerant. or worst, sasabihin may leak yung linya kaya nauubos ang refrigerant...
another cons, kapag nakatsamba ka ng AC shop na hindi marunong magbaklas at walang proper tools yung mga gagawa, susungkitin ng screw drivers mga panel at trims, then pagbalik hindi naisosoli ng maayos kaya may rattles na o mga kalampag na sa loob ng cabin[emoji6]
January 26th, 2024 05:56 PM #13
same with my old monty. ipina-check ko sa AC shop last summer, may leak kuno, need cleaning quotation 6.5k. magkano top up lang ng refrigerant kako? 650 kesos...sige top up lang...1yr nang mahigit ok pa lamig
- 54,205
January 26th, 2024 05:58 PM #14
- Sep 2010
- 3,027
January 26th, 2024 06:20 PM #15Sa Mazda 3 club may mga bad experience with sub zero. After daw mag pa cleaning, after a few days nawala yung lamig. So ofcourse bumalik sila to complain. Bastos daw kausap yung may ari. Sasabihin na hindi daw nila kasalanan. Sira na daw in the first place & wag daw sisihin sa kanila. Kahit umabot pa daw sila ng korte, panalo daw sila.
- Jun 2011
- 1,235
January 26th, 2024 11:49 PM #16
- Sep 2010
- 3,027
January 27th, 2024 01:39 AM #17
- 54,205
January 27th, 2024 10:47 AM #18there's two ways i see it,
first, is there some thing unique with the mazdas, making them prone to leaking after servicing...? and
sa tagal na niya sa business, bat hindi alam nang aircon shop, na ganun nga? gawan sana niya nang paraan, instead of simply criticizing the car.
from personal experience,
shop owners who say, "wala silang kasalanan" don't know enough of the technical and non-technical aspects of their business.
instead of hand-washing, they should offer possible solutions.
"this is what we did, sir... when we fixed it and returned the freon pressure to normal, you probably sprung a leak at some other part of your aircon, as a result of the increase to normal pressure. it's something we see from time to time that's really no one's fault. we can trouble-shoot it and offer solution, but as it was not in our original work coverage, we may have to charge more. i hope you understand, sir.". or something to that effect.
then again,
there's always the costumer from hell...Last edited by dr. d; January 27th, 2024 at 12:21 PM.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
